Results 1 to 10 of 17
Thread: Not happy!
    forres
    Default Not happy!
    1800 miles in my new veccie, and the coolant light comes on, open bonnet to find coolant tank bone dry, looks like its all leaked out of the connection.
    Full Member Big Sig's Avatar
    Did they forget to tighten the hose or something?
    it will be a spring clip, so the tension is preset..
    it could be a split hose, or split tank, or misfitted clip...
    take it to the dealer and have a rant..
    Sunny Dartmoor
    Hope you get it sorted m8............
    forres
    Car is now stuck in the dealership, as they can't find where its leaking from, and they have given me the most pathetic hire car going, an agila !!
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    they should of been ablke to find it once the put a pressure kit on to the header tank
    yep... dealers are asleep on this one......
    forres
    Apparently they pressure tested it, but as its a saturday, the main workshop is shut.
    a pressure test will show any leaks as the air pressure forces water out of any leak/split/crack....if there is a leak anywhere on the system the test will show it easily...it's foolproof and the results are instant
    Quote Originally Posted by snowball1 View Post
    thay have fobbed you off m8 as they cant be bothered to look
  1. Full Hunter alignment - One very happy member and one not so happy
    Last Post: 14th April 2012, 14:08
  2. She wasn't happy
    By dannyjpuk in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2011, 09:27
  3. Job done and happy out
    By MURDO in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 21:54
  4. HID Happy :)
    By kirky2k4 in forum Styling
    Last Post: 4th February 2011, 23:37
  5. I'm happy..........
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2008, 09:47
