Results 1 to 10 of 24
Thread: Tyre Pressures?
    Regular Member maz's Avatar
    Lincoln
    Default Tyre Pressures?
    I hope this is in the right place. Can someone confirm for me, i know it says the tyre pressures in the hand book but there are so many different combinations on the net etc. Last time i had a tyre fited the bloke inflated it to 37. Discussion led to the fact this is what he believes it should be at and it states on several websites that 37/38 all round is the best psi. Handbook states 32 front and 35 rear (without double checking, sure someone may correct me).
    Any thoughts greatly appreciated.
    Maz
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    WEll speaking with Mark (GSI3.2) at Trax on sunday he advised me for 18" tyre pressure is the same as 17" and that was 36-38psi, i run on 37 as its in the middle hth
    Lincoln
    Should have mentioned i have standard 17" on my SRI. How do you find it runs? Have you ever used lower pressures?
    N. Ireland
    why is gsi3.2 and the tyre fitter right and vauxhall wrong? i`d like to know why 37 is better. i run mine at 32 but if 37 is better ill put some more air in them
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    was told to double your wheel size and add 2 lb so
    17 = 36
    18 = 39
    19 = 40
    mine was at 32 but since being told that, increased it to 36 all around
    Midlands Mod Shop - NFFC.
    N. Ireland
    Quote Originally Posted by ditchp View Post
    17 = 36
    18 = 39
    19 = 40
    does the car feel any better for this or is this something you tell your wife incase she has a flat and there is nobody to help. double it and add 2 for luck
    Lincoln
    This is what i am trying to get at. I understand that vauxhall will state tyre pressures that are suitable for the make/model of vehicle but is there something behind it all that is explainable? e.g cars can go faster than they are limited to but won't due to other countries regulations that also needed to be taken into consideration when in production. Vauxhall do state however that a higher psi for fuel economy in the handbook also.......
    Lincoln
    17 = 36
    18 = 39
    19 = 40
    Maths never been my hot oint but (18 x 2) +2 is 38 ....
    Jul 2006
    Northampton
    Trim : Sri
    I think it runs fine, not had any problems and it feels more controllable than with lower pressures. i used to run 32 all round but found it runs better with increase pressure. tbh most people that work for vx are trained by monkeys in the zoo, thats why i hate the dealers and would believe members here over vx staff
    Lincoln
    Ditto. Never had the best service from dealers as i'm sure everyone would agree. More likely to trust my local family run garage. Years of experience and treats customers as they would want them to return. Pressure increase in the morning then see how we go.
  1. Tyre pressures
    By Chewy72 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2012, 01:00
  2. Eco tyre pressures
    By Mike57 in forum Handling & Braking
    Last Post: 29th February 2012, 14:31
  3. Tyre Pressures
    By Tango in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2009, 00:10
  4. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  5. Tyre Pressures
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2006, 00:49
