Thread: dead spot
    Feb 2007
    GREENOCK
    Default dead spot
    have a dead spot somtimes when i try pull away..from a standing start or when changing gear..1.8sri facelift..can you help
    Regular Member Andy17899's Avatar
    Jun 2007
    West Midlands
    Vehicle : Vauxhall Vectra SRI XPII
    Mileage : 68K
    Clean panel filter?
    Feb 2007
    GREENOCK
    thanks for reply.....wheres that and how do you it..is it a easy job
    Jul 2006
    Mexico
    Yeap..maybe a new airfilter a good plugs might do the trick
    Jul 2006
    Mexico
    Quote Originally Posted by bigcraig View Post
    The air filter mate...on the airbox ...just undo a couple of torx screws around thake the top off and check if the airefilter is clean. 5 min job
    Jun 2007
    West Midlands
    Mileage : 68K
    Theres a How2 in the HOW2 section, its on how to change it, so shows you how to access it.
    Feb 2007
    GREENOCK
    thanks for that
    Regular Member sparky71a's Avatar
    Apr 2006
    At the Garage
    Hi mate, no problem here! Flat Spots Be Gone!!!!!
    Change your spraks to NGK Copper or above such as Platinums.
    Next Get an After market Panel Filter in your air box,such as BMC (which is wot i use)
    Always run on 98 ron fuel or above such as Tesco 99 Ron, or Shell V Power(again wot i be using)
    Now just inside your air box there is a wee little bit of plastic you can remove that increases the area of suction over the filter,look up 'airbox mod' on the forum.
    Lastly you can consider ripping out your current cold air feed to the air box and spend 7 quid on the 3.2v6 air in take,It's much shorter and does not run over the engine thus bring warm air in to the box,with the shorter intake lots mor cool air goes into your engine,and ever so slightly adds up to making A DIFFERENCE!!!!
    None apart from the sparks are expensive things to do (that depends on your fuel consumption of course!!!!) but you flat spot should be then dead and buried!!! Hurrah for cheap mods
    Jul 2006
    Mexico
    This might help
    air filter...+ airbox mod
    http://forum.vectra-c.com/showthread.php?t=54506
    Upgrading to a GSI (VXR) intake
    http://forum.vectra-c.com/showthread.php?t=54505
    Jun 2007
    West Midlands
    Mileage : 68K
    Quote Originally Posted by sparky71a View Post
    WHich of the above affects fuel consumption :S
  1. is my cat dead?
    By victorM in forum Engine & Drivetrain
    Last Post: 29th September 2011, 21:34
  2. Evo is dead....
    By spoons in forum General Chat
    Last Post: 3rd March 2011, 16:26
  3. Dead
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 28th October 2010, 21:06
  4. Dead JVC
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 11th January 2009, 21:16
  5. ECC dead... why?
    By stevedee3 in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2006, 12:30
