Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: Brake bleed problem? on new upgrade.
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Default Brake bleed problem? on new upgrade.
    Hi Guys & Ladies!
    Just got myself into a little corner....
    Just got round to installing the 314mm brakes from saab guys. went on easy enough, but i have no brake pedal!
    I have been told its an airlock, i have bleed over 2l of fluid through the system, it makes no difference. I pump up the pedal, switch on the engine and the pedal hit the floor! (slowly) so i think i still have air in there, is there any tips..??? could the calipers be ****ged? and air is getting back via the caliper? anyone else had a doggy brake? or is it the dam air stuck in the system?
    thanks guys, dont know whether to put the old ones on and be done with it now.
    East Midlands
    More than likely to be air in system...?what method did you use to bleed.
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    used gunson easy bleed, cant see anymore air coming out, the brakes work at about 40% but the hardly any resistance to the pedal... i think its air, but it must be getting in somewhere, a friend has said it may have a seal fault, but cant see any leak...anywhere.
    even tried gravity.... did the rear N/S and front O/S and vice versa, then rears together and front etcs.. every combination, still no pedal... or handbrake..
    any ideas chaps... Any VX mechanic know is there is a specfic order??
    Admin plasma's Avatar
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    silly question... check the bleed nipples. make sure they are uppermost on the caliper. I fitted mine on the wrong side and this makes the bleed nipple sit lower thus trapping air in the top section.
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    plasma.. kindly noted... but the nipple is located on the side, not the top. (i think) :-) will check again tomorrow.
    East Midlands
    ?Did you open the bleed nip up when you pushed the pistons back.
    Full Member Big Sig's Avatar
    Quote Originally Posted by macdad View Post
    He has fitted new calipers so wouldn't have thought that was needed?
    East Midlands
    Yes was just thinking about flipped seals in master slave cylinder...sorry.
    Good point, but hopefully its not possible with the new calipers.
    On the Forum
    256 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by dv8 View Post
    Yep, its on the side but if the calipers are on the wrong way round its lower than it should be.... Did you happen to do the rear pads by anychance as well?
  1. Brake Upgrade Problem.
    By bigboynigs in forum Suspension, Wheels & Brakes
    Last Post: 9th July 2012, 18:27
  2. Brake bleed sequence
    By mungo1985 in forum Suspension, Wheels & Brakes
    Last Post: 5th January 2012, 16:14
  3. Full brake bleed
    By DNS in forum Vectra C / Signum Troubleshooting
    Last Post: 24th June 2011, 20:06
  4. Brake bleed sequence
    Last Post: 23rd January 2009, 05:37
  5. Brake and Clutch bleed
    By GoldenWonder in forum Suspension, Wheels & Brakes
    Last Post: 11th September 2008, 20:21
vectra c flipped seals
