as above what symptoms would a car get if this were to go bad?I had noticed a couple of times today that the car kangarooed a bit and the temp went down to 0...also where is it located on the 1.8(I must invest in a haynes sorry)
quote from haynes is....
the sensor is located on the thermostat housing on the right hand end side of the cyclinder head......
does also state you should remove then engine cover dont know if you have to do this to see it or if mr haynes is having a laugh lol
as for symptoms i wouldnt know on a petrol someone else might though
hope this helps you
thanks....will try to take it out and clean it first before buying a new one
