Results 1 to 10 of 11
Thread: 3,2 v6 oil on front pipe
    Regular Member speedzone's Avatar
    Dec 2005
    Uppland,Sweden
    Vehicle : Opel Vectra Caravan
    Trim : Sport
    Engine : 3,2 V6 AT5
    Mileage : 140000km
    Default 3,2 v6 oil on front pipe
    have an small oil leak thats dropp on the front exhust just at the 90 degree back under the engine
    its not a good smell inside the car i can thell ya
    where is it coming from? i have not a clue, cant see!
    is it to rip down the cambelt covers or what ?
    can anyone advice me please
    Jul 2006
    Mexico
    Sounds like a question for MArk (GSI 3.2) or other chaps that know the 3.2 back and forth with their eyes closed.
    Sorry cant help you there
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    I bet it coming from the oil filler neck...i had this on mine............the advice i was given was "rip it off" but put the yellow oil filler cap back in its place
    Dec 2005
    Uppland,Sweden
    Trim : Sport
    Engine : 3,2 V6 AT5
    Mileage : 140000km
    ol right i look in to it... thanks
    ooh one other thing when on AC its sounds phffffffffffffffffff inside the cabin
    from behind the steering wheel and ther is only cool air from one (1) air duct
    what the f-c 2004 veccy w. 4750 miles on it and alredy to fall apart..
    if it's not the oil filler neck, it will more than likely be the camshaft cover oilseal as they are only a thin o ring and can leak.... replacement is the cure, not nipping down..
    the other problem sounds like either,one of the servo motors isn't directing the air correctly or that one of the pipes behind the dash isn't directing the air..
    can you feel air coming out of all the vents with the AC off and the fan at max speed?
    Dec 2005
    Uppland,Sweden
    Trim : Sport
    Engine : 3,2 V6 AT5
    Mileage : 140000km
    hej
    filler checked dry and fine*
    Gsi3,2 it must be it.. i check on the weekend i cant take it longer burn oil air in the cabin
    this oil drip com 1 (one ) day after i hade the 3,2 in for new halo plugs install and new auto trans oil of course i was in and asking what have you forgot to tight? no no its a under the belt housing bla bla any way iam soo sick of the burn oil taste now. must fix it....
    if they had the intake off to do the plugs, i wonder if they disturbed the camcovers..
    if it is wet with oil on it's lower edge, then thats where the leak is...
    do you have a picture of your engine you could post on here?......
    Dec 2005
    Uppland,Sweden
    Trim : Sport
    Engine : 3,2 V6 AT5
    Mileage : 140000km
    Default the oil drip project....
    hi i have desmantle the 3,2 in to kambelt area
    i have found out that the front camshaft seal is black and kaputt
    compered to the red and nice lookin other 3 ones.
    i sure can need some advice to change the bad one ...
    a lot of oil and grime from behind the cambelt housing
    the bad
    the nice
    is this the right tension?
    so oily in the intake is it OK ?
    i am going to the store now and shop for cambelt kit and waterbump and one camshaft seal....
    it shouldn't look as oily as that, thou the intake being a little oily is normal.. the engine in the cambelt area should be oil free....
    the tension on the vambelt is set up on the two little marks on the tensioner lining up..when you move it round with a 5mm allen key they will align, clamp them up there, turn the engine twice by hand, check the timing marks line up again and reset the belts tension.. you cannot use the 'twist' method on these engines..
    camshaft seals are easy with the belt off...normally it's the crankshaft seal that goes first thou...
    to change the camshaft seal, set the engine's timing up, install the locking wedges. with the camwheels locked, undo the torx bolt holding the relevant sprocket on..take the belt off now and change the idlers.
    pull the sprocket forwards off the dowel it locates on..next you have to get the old seal out.. you can use a 'pick' or drive a self tapper into it and pull it out..when you refit the new seal, make sure to not damage the inner seal face when you slide it over the end of the camshaft.. make sure it goes back in square to the engine..
    reinstall the sprocket on to it's dowel and onto the shaft..replace the bolt and tighten as far as you can with the belt off.. replace the belt and tension as above..making very sure you get the alignment 100% correct before you turn the engine..
    Dec 2005
    Uppland,Sweden
    Trim : Sport
    Engine : 3,2 V6 AT5
    Mileage : 140000km
    ol right tanks
    the parts are in ´tomorrow
    fingers xross'd ( little scared)
    some price orginaly in SEK here listed in pund
    308 pund for the parts on universal shop
    471 pund on GM store
    837 pund work and parts on GM (opel)
    512 pund work and parts on independent shop
  1. 3.2 gsi front Y pipe
    By TimTay in forum Engine & Drivetrain
    Last Post: 14th January 2011, 16:56
  2. 3.2 GSi front pipe diameter
    By Tennants in forum Engine & Drivetrain
    Last Post: 13th June 2010, 22:23
  3. 3.2 GSi front pipe
    Last Post: 25th April 2010, 22:26
  4. Front pipe dilemma:(
    By vecgsiboy in forum Engine & Drivetrain
    Last Post: 23rd February 2009, 19:08
  5. GSI Front pipe / Cat
    By John H in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2006, 23:47
vectra v6 smelling of burning oil
