Thread: Remote key stopped workin'!
    Apr 2008
    Northants
    Default Remote key stopped workin'!
    Guys,
    My facelift vectra C key remote has stopped working. It still physically unlocks doors, and starts the engine. I bought a new battery from ebay, put it in and tried it, it unlocked the doors once, but then won't work anymore apart from that one time. Do I need to reprogram it? It was dead for a couple of weeks before I put the new battery in. Do I need a new key?
    Cheers.
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Hmmmm if it will start the car then i would say no it doesnt need reprogrammed... but if it doesn't unlock the doors then i would try another battery incase it was a duff one... let us know how you get on
    Regular Member muffking's Avatar
    The fact that it starts the car only shows that the bit in the key half works. The job of the fob is simply to lock & unlock the doors. If it doesn't lock/unlock via the buttons then test the battery or try another one. If you still have problems & yours has a light that doesn't light up then it's time to get a new fob & have it paired to the car as the car wouldn't lose the program for your fob unless there's a serious ECU problem.
    Regular Member lesbo's Avatar
    Feb 2007
    ANGLESEY
    Unhappy key fob
    Have a similar problem with mine but for different reasons, ok I washed it as explained on another thread, and I've read most of the threads on remedying it. Tried putting key into ignition, turning ignition on but not starting then pressing one of the buttons to let the car reset the key as suggested!!! Result is the car only recognised that key that allowed it to do it's own thing. Did the same thing with GOOD key and reset it all. Am going to dealers to see if they can reprogramme it (£35) or bite the bullet and get new key ( £53 plus the programming and VAT). Not taking anymore risks / chances of b**g**ing the whole system or worse still the car opening the doors while I'm away and returning to an empty parking space.
  1. my baby in workin progress.
    By ba1ny82 in forum Styling
    Last Post: 20th June 2010, 12:01
  2. window switch not workin
    By keithv1 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2010, 21:47
  3. Remote key stopped workin'!
    By Last Turkey in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2008, 15:23
  4. wehey i got me tis workin
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2006, 13:13
  5. Image uploader not workin
    By armoured farmer in forum General Chat
    Last Post: 27th August 2006, 09:50
