Thread: Electric window one-touch issue!!
    May 2008
    Featherstone, West Yorkshire
    Default Electric window one-touch issue!!
    Hi all
    I got an '05 Vectra 1.9 cdti 150. Last week all my diagnostic warning lights came on, i lost power sterring and the engine conked out. The result was a stuffed alternator, which has since been replaced.
    Since i've had the car back though, the one touch operation on the passenger side electric window has ceased to work!! Is there any kind of reset that needs to be done, due to the drain of the battery etc?
    There is also the car and spanner light that comes on when you turn the key to the iginition point. I've read another thread about this light and understand it should go off after 30 days/engine starts, but could this be something to do with the window problem..?
    The one-touch function on the drivers window still works......
    Thanks in advance to all
    Tyger
    Full Member Big Sig's Avatar
    Hold the window down button until it stops and you should hear it cut out. Do the same for it by raising it to the closed position. Not sure if you need to do both front windows together. The spanner light will be dur to the alternator as you have said. hth
    Sunny Dartmoor
    Lower window right down and raise it back up and that should restore one touch function,the light won't have anything to do with the window problem,hth.........
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    i just touched the up button for a couple of seconds thats what it says in the handbook do each window separately
    for the spanner light disconnect the battery for about half an hour and that will clear the spanner light but it will come back on if there is still a problem there
    Regular Member poves's Avatar
    lancashire
    Send the window down and hold the button for 5 secs , then send up and hold for 5 secs .
    This will reset the memory.
    11 Post(s)
    You don't need to hold the button down once you've opened the window.
    The correct procedure is:
    1. Close doors.
    2. Switch on ignition.
    3. Open windows completely.
    4. Close window and press on button for at least 3 seconds.
    5. Repeat for each window.
    May 2008
    Thanks guys. One touch is now restored. Though i'm not sure which method did it.
    Aug 2009
    bridlington
    1. Close doors.
    big daves way worked for me
    Glasgow
    God knows how you managed to dig this up after 2 and a half years.
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    ^^^ thinking the same lol
  1. One Touch Electric Windows Not Working
    By SteveBray in forum Vectra C / Signum Car Chat
    Last Post: 28th May 2012, 11:59
  2. Electric estate boot issue
    By dreams3577 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2011, 08:30
  3. lost one touch window close after clutch fitted
    By mat osborn in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2008, 17:18
  4. one touch window faulty?
    By jonnye in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 20:14
  5. Electric window issue ???
    By shan in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2007, 21:25
vectra c electric window reset
electric windows go down but wont go up on vectra 1.9 cdti 2005
why does my vauxhall insignia come up with the message lower and raise the rear window
how to reset front windows on a 2007 vauxhall astra
vauxhall vectra c window press up n goes down n wont come back up
vectra c one touch windowsopel zafira reset windowzafira electric window resetastra electric window resetastra g window lose calibrationhow to get my windows to go down with one touch a button on a Vauxhall Vectra Copel insignia window wont go down and lights wont go on03 opel astra window switch doesnt open with one touch of the buttonvauxhall vivaro one touch window resetastra electric window auto downzafira window inisialatingastra auto window resettrubelshooting windov opel vivaro2007 astra window one touch wont programvauxhall zafira no one touch windowsreset electric windows vauxhall zafirareset electric windows vauxhall astravauxhall vivaro 2016 electric window resetrecalibrate vauxhall electric windowvauxhall astra 2006 windows reset one touch
