Results 1 to 10 of 22
Thread: problem with new car!!!! 6 days old!!
    Regular Member vectramad's Avatar
    Jan 2008
    portsmouth
    Exclamation problem with new car!!!! 6 days old!!
    sometimes when putting in reverse it grinds into gear!!!, is this normal for a new car
    today i was parked up foot to the floor on the clucth,put into reverse say about 3-4 times and all i can hear is ****** grinding, eventually it got in gear nice and smooth.
    the car has only done jusr over 200 miles
    thanks
    Full Member Big Sig's Avatar
    Try putting it into first before reverse, or letting the clutch up before selecting reverse. Not sure if reverse on yours has a syncro or not.
    Jan 2008
    portsmouth
    why first then then reverse
    Because of the way reverse is selected within the gearbox. Just thought it may help.
    Jan 2008
    portsmouth
    it sometimes grinds into 1st gear,but ive not heard it grind for awhile in this gear just reverse at the mo
    I would take it back, I don't remember any other threads like yours. Just try all the possibilites first as they are bound to suggest them too.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If you are trying to select reverse when still moving it does this. Reverse is not synchro like the other gears it is an idle gear which sits between the intput and output gears when reverse is selected, when you come out of reverse this gear moves out from between the two gears (input and output). If the car is moving the input and output ones will be and if you are selecting reverse gear when these two are spinning (ie the car is rolling) it will crunch as this idel gear is being forced between these moving gears. This is sometimes why reverse does not always engage easy, the teeeth on the input, output and idle gears are missalined - thats why you are told to drive forward then try reverse again
    Gazza4
    Jan 2008
    portsmouth
    cheers m8
    things like this really **** me off
    Jan 2008
    portsmouth
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    drive forward then reverse again!! but thats not what i should be doing
    this happens when im idlie
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by vectramad View Post
    Perfect normal to me pal i wouldn't worry about it. Gearboxes and clutches have never been Vx strongest car part but they are decent enough - there's nothin wrong with yer motor. Mines does the same when its wants.
    If you really want to know what transmission worry is then how about a rattling sound when the clutch is at biting point andwhen the car is revved with clutch engaged and in neutral, the rattling returns when i take my foot off of the accelerator! if i'm lucky a clutch bearing (£700) if fate really has a grudge its my flywheel £1500 exclusive off labour which is 6hrs worth as the sub frame has to be dropped
    Gazza4
  1. Its been one of those days...
    By Diet1985 in forum The 'Off Topic' room
    Last Post: 13th August 2009, 23:23
  2. been one of those days so far.........
    By PeterVV in forum General Chat
    Last Post: 23rd November 2008, 21:53
  3. Those were the days...
    By Ian-Highlander in forum Non Vectra C/Signum Album
    Last Post: 1st October 2008, 15:30
  4. 5 Days to go .....
    By DennisTheMenace in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2006, 00:39
  5. 10 days old and.........
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2006, 17:48
