Results 1 to 10 of 11
Thread: 1.9 cdti cam shaft 54 plate
    Epsom
    Default 1.9 cdti cam shaft 54 plate
    Help! My vectra 'popped' while moving off on Sunday. The engine died, would not restart and the spanner light came on. Turning the engine over, I could hear rattling. The AA man showed me that my cam shaft wasn't moving and towed me to my local dealer.
    The dealer has had the car all day now but still can't tell me what is wrong. It may be a sensor at £200 or a whole engine.
    I fear the worst, even though it has only done 58k and has been regularly serviced by them.
    I guess it's got a timing chain. Should I expect it to fail after 58K? Should the dealer have changed it at a previous service? Is this a common fault?
    Any thoughts gratefully accepted
    Full Member Big Sig's Avatar
    It has a belt not a chain. How old is the car? still covered by warranty? If the starter is turning but the cams aren't then I would have thought it has to be a belt problem? But in saying that the AA and the dealer would easily be able to tell you this.
    edit:just realised its a 54 plate
    Epsom
    Thanks. Do you think the belt should have been replaced in the recent service? If the cam belt has gone does this mean trashed pistons?
    Would have only been replaced if it was due and if they wanted to pay for it. I think they are supposed to be done at 80k or 8 years on the 1.9 150's. It would probably mean trashed valves.
    Bristol
    Vehicle : CDTI 150
    If your cam belt has gone then get on to Vx customer dervices. As your car has received a full main dealer service then push the fact that the cam belt has failed well inside of its specified life and was therefore not of sufficient quality.
    Epsom
    Thanks for the replies.
    The dealer has just rung back to say the belt has gone and they are investigating how much damage has been done to the head / valves. They implied that Vauxhall should pay and would persue this when they had a full list of damages.
    I'm not counting my chickens yet.
    Just make sure they do not intend to bill you in the mean time!
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by ianp View Post
    Any further news yet m8?
    Epsom
    Not yet. They are busy but thought they could look at again today.
    Epsom
    Vauxhall are saying they will not contribute to the fix! We have been talking to the customer services people on 0845 0902044. Is there somewhere else I can contact? How can a CAM belt failure be our problem?
  1. Vectra c Sri 52 plate passengers drive shaft
    By mossy2432 in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2012, 15:25
  2. Replies: 15
    Last Post: 4th February 2012, 00:18
  3. signum 3.0 cdti o/s drive shaft
    By marktaylor in forum Engine & Drivetrain
    Last Post: 21st June 2011, 13:29
  4. Piston and crank shaft - CDTI 120/150
    By zafira in forum Diesel Engine related
    Last Post: 26th November 2010, 21:09
