Thread: Creaking
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Default Creaking
    Hi Guys
    Having problems with Creaking coming from the back of the car i have taken it to be looked at as i thought it was the exhaust but its not.
    it seems to be when i am coming off a corner and Straightening up.
    it sounds like there is somthing loose but theres not any ideas would be great as its starting to drive me mad!!
    Apr 2008
    Liverpool
    Has nobody had this problem what so ever?
    N. Ireland
    Try Putting Wd40 On The Radiator Springs At The Top Of The Radiator. There Is 2 Altogether. One At The Top Left And 1 At The Top Right. Could Be A Load Of Different Things But I Had Some Thing Simalar And This Fixed It
    Jul 2006
    Mexico
    If it is on the back of the car it could be those heat shields near the exhaust...might be worth to check on those
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    I had a creaking noise on moving off convinced it was from the rear of the car turned out to be the radiator mounts at the front.
    N. Ireland
    Quote Originally Posted by john_k_sri View Post
    me to, thought it was the suspension or something
    Apr 2008
    Liverpool
    I will have alook at the radiator mounts tonight if a get a chance but it does sound like its coming from the back of the car will have to double check.
    i have had alook at the heat shield when the guys were checking the exhaust it seems to be inplace well enough and does not seem to move.
    anything else i should try
    Stafford
    Once Again, THANKS - I'd just booked my car in to get the replacement mounts fitted (£90+) before tracking this thread down - managed to oil, test and call the garage to cancel within 5 mins......To think that it's been driving me nuts for the past 18 MONTHS!!!!!!!!!
  1. Rear end creaking.
    By MickAP in forum Vectra C / Signum Car Chat
    Last Post: 29th January 2013, 18:31
  2. Rear end creaking causes??
    By Bloicy 3.2 V6 GSI in forum Vectra C / Signum Troubleshooting
    Last Post: 25th March 2012, 14:35
  3. creaking
    By marc vectra sri in forum Bodywork & Interior
    Last Post: 25th August 2011, 08:13
  4. Creaking Window
    By logi6260 in forum Bodywork & Interior
    Last Post: 27th May 2008, 13:46
  5. creaking noise
    By signumboy in forum Suspension, Wheels & Brakes
    Last Post: 14th March 2008, 22:44
