Thread: aerial
    Regular Member signumT's Avatar
    grimsby
    Default aerial
    right some little barsteward has tried nickin my alloy aerial but id stud locked it on so now its all floppy and the base is u/s
    anyone got any piccies or technical drawing on how to remove old base and fit new im presuming its only held in by one nut and the amplifier wiring so shouldnt be too technical
    any thoughts greatly appreciated
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    I remember this been tricky. You have to drop the headlining and you will see a nut (quite big), from memory though i think the coax disconnects further down the line by a special plug. The aerial will come loose but as i have said the coax is a dog to loosen.
    Have a look and a play and you'll see what i mean. Can't remember exactly but something complicated it for me.
    Regular Member Robward27's Avatar
    Witham
    Prob be similar to fitting the extra light to get the roof lining down
    This PDF shows the aerial removal. As Paul said, you'll need to drop the headlining. I would've included the bit for that, but all TIS had was stuff relating to the front headlining/lamp/storage area - which was fairly serious stuff!! lol
    I'm sure the rear headlining on the Signum just pulls down, but I've never done it myself!
    HTH
    grimsby
    thanks duncan i knew you wouldnt let me down
    I do try - or at least that's what the wife says!
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Had time to recharge my memory on this one now. On mine the coax going in to the aerial base was fixed and couldn't be removed. If you trace the coax away from the aerial base by about 20 inches or so you will come across a jointing block. This is where the aerial can be disconnected from the main coax feed to the front of the car. It is a pressure type release to unplug it from the main feed. If i remember correctly the coax from the base to this joint is thinner than from the joint to the front of the car.
    Hope this helps,
    Paul.
    P.S. I'm gonna start calling Duncan 'pdf'!!!
    Joking aside, he's a great help with them.
    grimsby
    wots peoples thoughts on replacing with this
    http://cgi.ebay.co.uk/WORKING-SHARK-...QQcmdZViewItem
    Quote Originally Posted by leeds vectra
    Thanks m8, I've certainly passed a few in your direction!
    Quote Originally Posted by signumT
    Never really been a fan of shark fins, based on seeing them on Beemers. Difficult to judge without seeing it on a Vec!
    grimsby
    come on duncan thought youd have done a photoshop
  1. vec c aerial
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2012, 21:33
  2. aerial
    By matreya in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2012, 15:42
  3. How much is a new aerial?
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2010, 15:00
  4. tv aerial
    By VEC-MAN in forum General Chat
    Last Post: 28th February 2010, 12:41
