Thread: Suspension Coil Spring Question
    Mar 2007
    Attleborough, Norfolk
    Default Suspension Coil Spring Question
    Good morning all
    I have found what could be half a coil of a suspension spring on my mates drive and I rather fear it could have come off my Vectra. There is no sign of where it came from on my car but I have been told that this is a common fault on these cars and won't necessarily be obvious.
    I have a MOT & service booked for next week and my local garage man is going to have look closer around the springs for this. If I have to have a spring (or are they replaced in pairs) replaced with Vauxhall ones are they likely to go the same way?
    I have seen threads here before about alternative makers of spring but are these for lowering or other such change of use? How much do springs cost these days?
    Any info on Vectra springs would be most helpful.
    Thanks.
    Brian
    Sunny Dartmoor
    I'm sure you'd notice if you had lost part of a spring m8,would'nt go for Vx one's as they are $hit,go for Eibach which are half the price £145,yes it lowers the car 30mm from standard SRI/GSI ride height but will last alot longer and give you a better ride.......
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I think the eibach springs have a 5 year warranty compared to VX which is 30 seconds after fitting!
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    It may well be off your motor, get it checked.
    I had a coil snap off one of my front springs on my old Vectra B, the only way I realised was the car sat at a funny angle when parked on flat ground!
    Mar 2007
    The car looks to sit level but then the bit of spring I have is half a turn. I was told that it it not unusual for a piece like this to break off the end and just sit in the cup or whatever the coil springs sits in.
    My Vectra is a 1.9CDti SXi and looks to sit fairly low to start with. Weren't these suppose to be a bit lower and stiffer as standard? Is there not an alternative supplier of springs for the original Vauxhall ones?
    Brianh
    Regular Member boba's Avatar
    The Kingdom of Fife!
    Quite common for part of the last turn of a spring to snap off. Not restricted to Vx either as I've had it on another couple of cars. You don't really notice if it's a small piece broken as it doesn't affect the way the car sits any more than normal road camber. Certain MOT fail even if its only the last little bit that's broken off (sounds more in your case though).
    Mar 2007
    It sounds so likely especially as the broken bit is half a turn of the coil and looks to be the same diameter as the spring material. Do these springs have to be replaced in pairs do you know?
    Thanks.
    Regular Member colalowe's Avatar
    in the North
    Yep you should always replace in pairs.
    If you get the eibach springs and your car is already at a lowered height then you shouldnt notice much of a height drop if any, but the springs will be far better than standard.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    yes springs and shocks should be changed in pairs, if it of your car then the car should sit lower one side? but as you have mentioned that it doesn't so best bet is to get it checked out asap and go for eibach spring that have also been mentioned as these will lower the car slightly and handle much better
    Quote Originally Posted by brianrh View Post
    They should be because after a while the spring starts to settle a bit so a new one will be a bit longer and sit a bit higher. If you've not done many miles though (and if your wallet's a bit thin) you could get away with changing just one.
  1. Coil Spring Again
    By Wolfie01 in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2012, 22:30
  2. Coil spring
    By GAV_SRI in forum Vectra C / Signum Troubleshooting
    Last Post: 7th May 2012, 18:07
  3. Coil Spring Compressor
    By BYGino in forum Handling & Braking
    Last Post: 23rd February 2012, 23:25
  4. Snapped Coil Spring
    By Exclusive BV in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2010, 23:01
  5. Broken Coil Spring??
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 5th November 2009, 23:20
