Results 1 to 10 of 11
Thread: wheel bolt dethreaded
    edinburgh
    Default wheel bolt dethreaded
    Hello all first time on the forum. I have a query. while checking my brake pads on front of my vectra i have noticed one of the wheel bolts has been dethreaded. do i have to purchase a complete new hub or could i get away with a rethreading tool. Your help would be appreciated many thanks
    Graham
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Hi mate,pretty suprised no one has replied....
    Depends on the extent of the damage to be honest mate...has the stud stripped? if so the hub may clean up with a tap....
    Get someone to look at it for you to see the extend of the damage ,You may be lucky...or have to replace the hub...
    Heres hoping its not the later.
    Chris.
    P.s welcome to the club.
    Regular Member dan9895's Avatar
    Apr 2008
    exmouth devon
    i dont know a great deal about this to be honest,
    like dose said i should get it checked out by thr pro's........ but personally for safety reasons i would replace the hub i dont think it would ever be as strong as it should be cause its a layer of metal stripped away,
    probs expense you dont want,
    my old dad used to say better to be safe then sorry
    welcome to vectra-c though!!
    edinburgh
    thanks dan and dose. willlet you know how it goes.
    cheers
    Maida Vale
    The bolt is the bit that you take off when you remove the wheel....do you mean the threaded hole the bolt goes into is de-threaded?
    Quote Originally Posted by Dose View Post
    Remember, most people may have been at Trax yesterday
    As has already been said, which bit is damaged, is it the bolt that has no thread or the hole? Which thread has been stripped?
    edinburgh
    The threaded hole in the hub is stripped as is the actual bolt too.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Has the bolt left its thread behind in hub giving the appearance that the hub thread is stripped? If it has it might clean out and you would only need a new bolt
    I would try to tap the thread out in the hole and try a new bolt. It may well need a new hub
    edinburgh
    success. took it to local vxhaul dealer. they wanted to replace brake disc,pad, wheelhub with bearing attatched and 4 new bolts 533 pounds. went to local friendly one man garage, tapped bolt in and replaced bolt.tenner. sorted. thanks all
  1. Wheel bolt help
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 31st August 2012, 02:05
  2. wheel bolt size?
    By swifty_53 in forum Handling & Braking
    Last Post: 23rd March 2011, 17:50
  3. Wheel Bolt Caps??
    By OPC in forum Suspension, Wheels & Brakes
    Last Post: 7th April 2010, 22:27
  4. Snapped Wheel Bolt
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 10:17
  5. Wheel bolt size
    Last Post: 5th July 2007, 08:40
