Results 1 to 10 of 16
Thread: loss of power-- turbo??
    Regular Member formby's Avatar
    paisley
    Default loss of power-- turbo??
    anyone know what the symptoms of a blown turbo are? I just booked a holiday and on my way home after paying that the car lost most of its power and limped home. I checked the boost hoses etc but no sign of splits etc but when i took the hoses off there was a layer of wet oil inside the pipes re started the car and there was a lot of whitish smoke from the back. is this a sign that the turbo is goosed or is it something less/more serious. im waiting for my sons friend to appear with his diagnostic kit to check the codes as the spanner light had come on during this but any advice would be much appreciated
    Full Member Big Sig's Avatar
    Always a little bit of oil. White smoke is water and normal. Blue smoke would be a goosed turbo normally.
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    have you checked both turbo hoses? Even underneath? And as Big Sig said there will always be a little oil in the turbo hose
    paisley
    took hoses off and checked them for splits, nothing showing. just started the car again and it could get a bit part as a smoke machine for THE FOG seriously there is a heck of a lot of smoke coming out the exhaust its dark just now so its difficult to tell wether its all white or maybe more blue. going to phone a friend tomorrow to see if he can take a look at it for me ( he runs a garage about 30 miles from me)
    Last edited by formby; 7th September 2008 at 21:37. Reason: pressed the wrong button
    Regular Member VinnyPeewee's Avatar
    Mar 2007
    N.Wales
    if its just white smoke (deffo smoke and not steam) then its unburnt fuel.. the assuming you have a diesel turbo and not petrol!! .. could be down to a faulty injector... 'hosing' fuel into the cylinder rather than 'spraying' it. this would give you a lack of power too as your engine wont be running properly due to incorrect fueling.. just a suggestion!! :P
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Under boost a pin hole will get larger, can you pressure test your hoses n any way, foot pump and water comes to mind.
    Regular Member dan9895's Avatar
    Apr 2008
    exmouth devon
    i had a similar problem.......
    found out the clever muppets at vx put then vacuum pump hoses the wrong way round,
    all that labour charge for what i wonder....... Its not there Brains!!
    so check vacuum pumps make sure there all working take off hoses with engine running make sure you feel it working
    paisley
    should have said at the start it is a 2.2 dti 53plate doh!!!!!!!
    thanks for the replies, hopefully when i contact my mate today he can have a look at it for me. I will post any info that he can give me
    Regular Member Elite2.2DTi's Avatar
    Jul 2006
    Southampton
    I've just had mine diagnosed with a blown turbo. It limped to the garage, and had blue smoke from the exhaust. :-(
    Still it will be back on the road by friday (hopefully) :-)
    paisley
    UPDATE: mate checked car out last night and it is a seized turbocar getting picked up today for repair and hopefully get it back on friday. he will do it for as little as possible but still expect a big billwill repost when fixed .thanks for everyones input, Vectra-c shows some people are always willing to help!
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. loss of power
    By STRETCH2009. in forum Engine & Drivetrain
    Last Post: 8th August 2012, 18:44
  3. 2L DTI '53 Loss of Power
    By BigTunz in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 17:27
  4. Loss of Power / Turbo Lag?
    By sirk696 in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2010, 22:59
  5. power loss
    By justyb in forum Diesel Engine related
    Last Post: 23rd January 2008, 02:22
