Thread: Dash Light
    Full Member spennny's Avatar
    Blantyre
    Default Dash Light
    Got a dash board light that looks like a light bulb with an exclamation mark in it, checked all my bulbs , any advice what it is
    will post a pic a bit later
    Regular Member Robward27's Avatar
    Witham
    What about numberplate light normally comes up with failed lamp description
    11 Post(s)
    Double check your rear light clusters.
    There are 2 tail light bulbs per side, and if one goes out it's not always noticeable. Also one of the pair doubles up as your brake lights - but if one bulb fails, the other bulb then takes over the role of tail/brake light.
    Ultimately though if all bulbs are working, then you will have to go round and clean the contacts on each and every exterior bulb and the holders.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Quote Originally Posted by Robward27 View Post
    mine doesnt i have just discovered a bulb out on my numberplate and there is no bulb failure come up on the computer
    Blantyre
    Cheers ROB, did notice it was out a few says ago and then came back on, i will check that
    Sunny Dartmoor
    Number plate bulbs don't trigger the warning system on my veccy,maybe a rear bulb as it uses the side light for break light when one is out......hth
  1. Light on dash
    By topline in forum Electrical & ICE (including SatNav)
    Last Post: 3rd August 2012, 13:00
  2. light on dash
    By kgb in forum Engine & Drivetrain
    Last Post: 27th January 2011, 21:05
  3. Light on on dash what should i do?
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2009, 12:54
  4. Light on dash...
    By dankidd in forum Engine & Drivetrain
    Last Post: 17th December 2008, 01:13
bulb n exclamation mark on dasdh of vauxhall vectre
