Results 1 to 10 of 23
Thread: small but ...
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Default small but ...
    The day went to do some small interiur mods... well everything takes time when 3 kids want to help.. and keeps asking questions..
    The first went fairly quick..
    A extra power outlet in the trunk, but this one on constant power, as the other is set up only working with ignition.
    (maby should be added to the how to.. as i took the power from above the 40 amp fuse seen on pic)
    Well the second mod was a pain in the ****. couldt be done with rooflining down.. so as to drop by opel as i knew that they had one with those on, to look where they where placed.. im reasonable please... not perfect.. but ok.
    Well the last mod was to change the way off my dvdheadrests.. so they no longer was dependant on ignition.. so used the plug below the 40 amp fuse (see pic above) and routed it in the the center colsole, and put a swich on.. there should be ligth in it.. but then it was there all the time (the light.. maby check tomorrow if it helps to swap wires)
    Last edited by kenp; 6th September 2008 at 19:38. Reason: pressed send to quick.....
    Jun 2007
    Black Country
    errrmmmm
    what are those things you fitted in the roof lining???
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Jun 2007
    Black Country
    Quote Originally Posted by Danwells72 View Post
    Phew, thought I was being thick for a minute then
    Regular Member ade's Avatar
    leicestershire
    they are to hang the rear dof fuard net i think. Ihave them in my zafira
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Some nice work there Ken, so with the rear power outlet if you take power from above the 40amp fuse the ignition controls the power and under the fuse is permanant live? Or is it the other way round, didn't realise you could wire it to come on with ignition.
    Engine : 2.2 Direct
    Quote Originally Posted by BigP View Post
    both above and below the 40 amp fuse is constant live.. but on the estate there allready wires for at poweroutlet thats on ignition live.. the only way else to make "ignition live" is to run a wire from the center console to the back i think.
    Quote Originally Posted by ade View Post
    Yes they are for the dogguard/vertical load restraing net (in a "rollo")
    Apr 2006
    Cheers for the info Ken. Keep up the good work.
    Apr 2006
    Sorry, double post, database error.
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    Awesome work there Ken, very impressed.
    Snowman, you got your ears on?
  1. Just how small is your *****...
    By Penfold101 in forum Comedy & Humour
    Last Post: 10th March 2010, 21:29
  2. Small Mod done
    By 3.2wales in forum Styling
    Last Post: 24th January 2010, 23:43
  3. small key help
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2007, 17:39
  4. A few small changes...
    By VectraMat in forum Quick Photo Album
    Last Post: 9th July 2007, 09:18
  5. A few small changes...
    Last Post: 8th July 2007, 00:21
