Results 1 to 3 of 3
Thread: turbo
    cleveland
    Default turbo
    I have just got a 52reg vectra 2.0 dti sxi how do I know if the turbo is working ok, the car just same a little flat to me
    Full Member Big Sig's Avatar
    You will hear it as it spins up. Without fitting a pressure gauge its difficult to know what boost it is producing. Do you hear any wooshing like leaking air?
    Regular Member VinnyPeewee's Avatar
    Mar 2007
    N.Wales
    Not too sure about your model.... but general rule of thumb too check turbos on most cars is either rev it up towards the red line (with a warm car.. not from cold!!!!) then throttle off suddenly... you should here the waste gate/ re-circulation valve 'woosh' and here the turbo spool up and whisle slightly. that way you know the turbo is producing pressure (although you dont know how much?)
    another way to check to make sure your turbo is boosting is to squeeze the turbo hose on the turbo discharge side (if its rubber and squeezable) squeeze it flatish.. and hold it flat.. while you do this get someone to rev the car up for you gradually upto wards the red again... and you should feel at about 2000-300 rpm the hose that your squeezing begin to build pressure inside and begin to open the hose and your hand up!!
    old school methods... but still used by many a mechanic today!!
    vinny
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. Turbo Technics Hybrid turbo details.
    By nutron in forum Diesel Engine related
    Last Post: 28th February 2011, 22:57
  3. TD04L14T turbo for Z20NET (2.0 turbo)
    By Caveman_nige in forum Parts for sale
    Last Post: 10th October 2010, 13:23
  4. Turbo Help
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 12th February 2010, 11:42
  5. is it possible to change 2.0 dti turbo to 2.2dti turbo
    By EURO G in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 07:35
