Thread: Drivers Door lock problem
    Apr 2008
    West Midlands
    Default Drivers Door lock problem
    Hi all, does anyone know how best to tackle a problem with a Vectra C door being closed, yet my central locking on the fob will not lock it. The HUD inside the dash states that my door is open, and signals through it's built in speaker. Not sure why this has started to happen, just got out my car the other day and tried to lock, and saw the malfunction straight away.
    Would simply removing the positive battery terminal, waiting a few seconds, then later re-fitting fix this?
    Thanks in advance, any help would be appreciated.
    Dave.
    The interior light switch is inside a sealed unit I believe (part of the door stay mechanism). Need to remove the door panel to access it.
    A search on here *may* well reveal whether someone has repaired one or not.
    Apr 2008
    West Midlands
    Thanks buddy for the help, saves me taking off the battery!
    Apr 2008
    West Midlands
    Default Still got the problem
    Hi all, did have a look for a post and found Calvin advised to adjust the striker plate, can someone tell me where to locate the "Striker" plate so that I can adjust this. I have removed the complete door panel and not found this torque 45 bolt with arrows locating different settings. Any help on this owuld be appreciated, and by the way its a Vectra C Elegance '03 plate.
    TIA!
    it's the plate on the B pillar.. the one next to your seat that the door locks on to...you just need to slightly slaken the two torx bolts and push it back towards the door seal about a mm at a time till the door says it's closed on the display..
    Apr 2008
    West Midlands
    Default Deja Vu
    Hi
    Thanks for the reply, gave it a go and what I did was slightly unscrewed the panel, and thought that I moved it. Tightened up the bolts again and closed the door and upon waving my fob at it, it locked! However, I looked back at the work I did and noticed that really I hardly moved the striker plate. This happened to me last time so I am going to see how I goes. I hope I don't have to take my torque wrench to work, good luck to the missus!
    Thanks again for the help, will report back if anything.
    Dave.
    May 2007
    Scotland
    Thumbs up Works for me
    Had the annoying, driver's door open warning light on when door is closed and car won't lock problem, followed gsi's advice and hey presto. Warning light off and car can be locked.
    Another few quid saved due to the forum.
    Cheers and Happy Christmas
    MOTM
  1. drivers door lock
    By eddy b in forum Vectra C / Signum Troubleshooting
    Last Post: 20th September 2011, 06:24
  2. Drivers Door Lock Switch Help
    By UltraVec in forum Electrical & ICE (including SatNav)
    Last Post: 27th June 2011, 16:31
  3. Drivers Door Lock not working
    By Rupster_69 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2011, 16:07
  4. De-lock Drivers Door...
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2010, 14:43
vectra c door lock removal
vectra c door lock problems
removing door lock vectra-c forum
opel vectra c lock problem
vectra c door not locking
vectra c drivers door.dead locked
ooel vectra door lock problems
vectra c door look sensor problem
vectra c troubleshooting doors wont lock light on dash
vectra 54 plate door lock removal
how to replace dorlock to drivers door on vauxallvectra c
vauxhall zafira door locking problems not impounded from drivers door
vectra c drivers door check catch
vectra door wont lock
vauxhall zafira door lock problems
https:www.vectra-c.comforumshowthread.php56930-Drivers-Door-lock-problem
vectra c drivers door locking mechanism
how to take out drivers door lock on vectra b
