Thread: Clutch Problem....
    Rotherham
    Default Clutch Problem....
    Hi folks newbie alert!!!!! Right i own a 2005 2.2 sri direct (love the car to bits just treated it to some yoko's c drives) but and here is the but the clutch clicks once it has reached the top of its travel ie whn releasted. it also slipped about 8 months ago under harsh acceleration and once again whilst going up a hill not been pushed since then its not skipped a beat it does engage low down biteing point. Right some history its covered 43k miles had an owner before. Does anyone have any ideas...... garage where we had it mot'd said it slipped on the rollers and to wait till it finally gave up the ghost is this a good idea and how much am i looking at to replace forgetting main dealers any ideas would be welcome common sense makes me think it should not be needing replacing so early in miles terms....
    Regular Member mspvxr's Avatar
    May 2007
    Chugging along
    Vehicle : Vxr in red
    Depends on the last driver.Wasnt a rental car was it?
    Rotherham
    Default Was it a rental......
    No car was not a rental car, fully realise if last owner was heavy with the clutch it would have an impact but after only 43k it should stand up to more than that well hopefully anyhows
    Rotherham
    Default Please re-look and help.......
    Could ppl please have another look at this anyone guess how much for a new clutch and fitting rotherham south yorks area
    Regular Member s0501291's Avatar
    Warrington
    Hi
    Dont know how helpful this is but, my clutch used to click when you release it, every time you push it down then release it. After a bit of investigation found it was a broken clutch pedal return spring and the 2 broken halves were causing the click, I removed the spring which stopped the click and then fitted the clutch spring kit which was released as a "fix" by vauxhall. The kit has a different type of spring to the one thats fitted by standard.
    Regular Member garvey's Avatar
    Co Durham
    I bought a clutch from the stealers the other day £291.
  1. clutch problem please help
    By v33tra in forum Engine & Drivetrain
    Last Post: 12th November 2011, 02:09
  2. Clutch problem!
    By kel123 in forum Engine & Drivetrain
    Last Post: 5th October 2011, 16:07
  3. Clutch Problem
    By ickleric in forum Engine & Drivetrain
    Last Post: 31st January 2011, 19:19
  4. clutch problem?
    By darko2301 in forum Engine & Drivetrain
    Last Post: 10th April 2009, 21:33
  5. Clutch Problem
    By Aimee in forum Engine & Drivetrain
    Last Post: 30th August 2006, 23:31
