Results 1 to 10 of 11
Thread: Airbox Mod
    Regular Member old cruiser's Avatar
    slough
    Default Airbox Mod
    Just been reading some positives to the Airbox Mod, relating to removing flat spots (which I have slightly), seems like most of the engine sizes benefit from this, what is the actual procedure for this mod? all as I could make out without spending too much time on the PC (works one!!) is some plastic part needs removing, what bit? any photos? as don't remember seeing any part that could be removed last time I changed the filter.
    Cheers Pete
    Sunny Dartmoor
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    i have an induction kit on my gsi would i be better off doing this or does it not make much difference?
    cambs
    Quote Originally Posted by vectragsi3.2 View Post
    if its a cold air intake kit then it should be fine as it is.
    if not change it.
    Feb 2007
    its the k&n but i have been told that the air is mostly hot that goes on it??
    slough
    Quote Originally Posted by glenboy View Post
    Nice one mate , exactly what I wanted to see.
    Cheers Pete
    slough
    Forgot to ask; does this Mod' really make much difference on the 2.2?
    Cheers Pete
    cambs
    Quote Originally Posted by old cruiser View Post
    Cheers Pete
    when i did my 1.8 i noticed the differance.
    but i did K&n filter removed cone and put the shorter air intake pipe and reset the ecu(just dissconect battery) all in one go and it took all the flat spot out and seemed to make it a bit more responsive.
    Regular Member Matty H's Avatar
    Bristol
    Cheers Pete
    I did the mod on mine and fitted a K&N Filter. Total and utter waste of time in my opinion. Not a jot of difference in anyway. No flat spot removal, probably because there were never any flat spots in the first place and certainly no difference in acceleration.
    Some say it works for them. That's fair enough, but for me it definately didn't make any difference whatsoever. in fact after about 2 months I put the old filter back and the plastic bit from the box to see if I'd notice a difference the other way round. No difference at all. I've left the plastic bit in there now and put the K&N Filter back in, but purely because I bought it so why not use it
    slough
    Quote Originally Posted by mhvcbv View Post
    When you say you fitted the shorter air intake pipe , was this the VXR one?
    Cheers Pete
  1. Airbox mod.....part deux!!! (rip off of VXR280 airbox mod)
    By paul_sri150 in forum Diesel Engine related
    Last Post: 30th January 2012, 22:50
  2. Airbox Mod!!
    By R-ford_Vec_C in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2010, 14:15
  3. airbox mod
    By andy_hare in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 14:29
  4. Airbox mod(But Why)
    By stanian in forum Petrol Engine related
    Last Post: 7th May 2009, 09:49
  5. Help with the airbox mod?
    By strothrc in forum Diesel Engine related
    Last Post: 9th April 2009, 15:10
