Thread: Pressure washer query
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Default Pressure washer query
    I have been thinking of getting a pressure washer for a while. I have been told in the past that the washers require a good head of water to work. Is this true?
    My problem is that the water pressure where I live is **** even though I'm nearly at sea level. Even the bathroom shower requires a pump.
    Regular Member Higgins's Avatar
    Dec 2005
    Aylesbury
    I thought the pressure washer acts as a pump anyway!. Maybe ring up karcher or whoever makes the one you want to buy and ask them for advice
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    The way most of the modern hobby type pressure washers work is by direct feed to the pump, so the pump will actually pull the water through the hose at the required rate. Only really the bigger industrial types that use a header tank now, good water pressure is required for these.
    Regular Member blr123's Avatar
    Dundee, scotland
    Hi Brocks,
    If you're after a Karcher drop Lee Cooper a line at: - coop69lee@hotmail.com
    He supplies at really good prices.
    Bryan
    And they work via a pump wich switches off when you release the trigger
    Feb 2006
    Wirral
    Thanks y'all
    Found THIS on a pressure washer site... It seams that the supply pressure does matter. I will have to look into this further.
  1. which pressure washer to buy?
    By MURDO in forum General Chat
    Last Post: 29th March 2012, 21:47
  2. New pressure washer!
    By GSiFan in forum Detailing and Car Care Discussion
    Last Post: 7th January 2011, 00:19
  3. Coolant top up and pressure cap query
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2009, 15:18
  4. pressure washer.......
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2007, 10:05
