Results 1 to 10 of 16
Thread: Question about Angel Eye headlights, can u use whiter bulbs??
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Question about Angel Eye headlights, can u use whiter bulbs??
    Hi all,
    I am thinking about getting some Angel eye Headlights.
    I have seen pictures of them on the forum and the ring/eye lights look a bit yellow.
    1.Do they use LEDs?
    2.Do they use standard side light bulbs which mean they can be changed for whiter light ones?
    thanks
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    Have you seen the thread by Hans Vledder ?
    "The rings are lit by 4 little T5 lamps for each ring, 8 per unit, prefitted (4 spare T5's come with the units). I need to find a few T5's that have whiter light than these."
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by sig63 View Post
    So they are not LED's then? They are the standard side light bulbs. I have some bright white T5 bulbs already fitted to my car so these should fit? Just need 6 more!
    I think the side lights are T10 and yes it would be 8 per side so would need 14 more)
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    no you need 14 more in total..........4 to each ring
    Northampton
    Engine : A20DTH
    Mileage : 88000
    So are the T5's that are fitted to the angel eyes LED or normal bulbs?
    I assume because of the yellow light they are standard bulbs.
    anyone?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Right after reading through Hans post it seems that the bulbs are normal ones. The issue seems to be that replacement LEDs are too long so will not fit. I would assume as well that if u put LED's in the "bulb out" indicator in the dash will come on or is there still a standard indicator bulb fitted?
    the 'bulb out' will still light even if the indicator is still a normal bulb.... the unit will still 'fault' as it will notice the LEDs in the headlamp unit and flag it as a faulty headlamp..
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by merikiito View Post
    sorry meant side lamp not indicator
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    same, vectras dont like leds. get some mtec t5s
  1. brighter /whiter headlight bulbs for a vec c
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2011, 01:33
  2. angel eye headlights
    By nidgeboy in forum Vectra C / Signum Car Chat
    Last Post: 8th September 2010, 11:51
  3. Headlights angel eye
    By sberrow in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2009, 15:27
  4. Angel headlights??
    By mitch1965 in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 21:21
  5. Angel Eye Headlights
    By Bucko in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2008, 20:05
