Results 1 to 10 of 14
Thread: NCDC 2013 CDC Safe
    Essex
    Trim : GSi and Elite with Eibach adaptive
    Engine : 3.2V6 and 2.8T
    Year : 03-06
    Default NCDC 2013 CDC Safe
    Just had the in-dash CD changer swapped for one that isnt broken but now get error 'CDC Safe' when trying to play something in the changer. The rest of the radio & satnav works fine and the change has power as I can insert and eject the cartridge - is there some code to fix this or do I have to get sh@fted by the dealer? If so what would they be doing and how much should it cost...
    ...or is there an independant guy who does such things??
    when the headunit (double-din with satnav and in-dash CD changer) was changed under warranty a few years ago I was told these radios dont have codes but they have to be 'coded to the car' somehow. No idea how that was done but didnt care as I wasnt paying for it...
    This time round (out of warranty) only the CD changer mechanism has been changed so not sure how one part of the double-din unit can be 'coded to the car' while the CD changer isnt when its part of the same thing!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Everything has to be Tech2'd in so u need to go to your dealer. You will need your cars secruity code.
    Everything is treated seperatly, Radio,Changer and Dab unit.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by merikiito View Post
    Half-canbus so no Tech 2 involvement on installation. Tech 2 only on full-canbus/facelifts. The unit in question is one that was fitted as standard to pre-facelifts, and has a 4-digit RADIO code.
    The message CDC SAFE implies that the unit is faulty or is not being recognised, and you should have been given the RADIO code with the unit.
    Essex
    Year : 03-06
    Quote Originally Posted by john_k_sri View Post
    'SAFE' merely indicates that the RADIO code needs re-inputting. Half-canbus so no Tech 2 involvement. Tech 2 only on full-canbus/facelifts.
    the dealer have not been helpful so far - they claim to have done a tech2 (its on the bill but they didnt charge me for it as it didnt fix the problem). Car is '53' GSi with the early style Vectra C lights (not the wraparound style).
    I have a 'car code' that's something to do with the radio - if that needs to be input how do I do that, there's nothing in the manual
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Mileage : 72K
    Yes there is in the Audio Manual, not the Owner's manual. You should have got one when you got the car, and the manual covers all audio units fitted as standard, including yours.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    No, not true and this has nothing to do with full or half CANBus: the NCDC 201x systems work the same way as the later CDxx units; it does not have a 'radio code,' only a 'car code' which is needed for the pairing via tech2
    Regular Member MysteryElite's Avatar
    Feb 2007
    North Somerset
    Quote Originally Posted by sig63 View Post
    I have an 03 Elite with the NCDC2013, and had an issue when I first had the car a few years ago. In my case all but the radio were showing "safe". For some reason the unit had lost contact with the ECU and had to be reset via Tech2. Was all done under warranty.
    As for the OP's problem - who switched the CDC mechanism over? If it was the dealer then they have not fixed it properly.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Mileage : 72K
    Thanks for that. Wasn't aware of that.......I wrongly assumed that the NCDC units were coded in the same way as the CDR and CCR ones should have checked my Audio Manual.....(RTFM !).....I live and learn.
    So a 'SAFE' message can imply that the unit has not been paired properly/fully to the car?
    Seems that pulseracing needs to go back to the dealer for them to do the business properly.
    If the radio and satnav are working does that mean that Tech 2 can 'see' them but not the changer I wonder.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    No the Car ECU knows it is there thats why it is saying safe as it is not coded to the car. Tech2 will know its there if it is working correctly and therefore u should be able to enter the car security code to activate it
    Essex
    Year : 03-06
    while those last couple of posts were happening, I was out in the rain checking the audio manual! Under the heading 'Anti-theft protection' it says:
    The Infotainment system is factory fitted with an electronic security system for anti-theft protection. A coded unit is useless to the thief. The unit is coded in the factory. If any problems arise, or the display shows "Safe", please contact a Vauxhall Authorised Repairer.
    what they should add is
    ... who will tell you its broken and that you should buy a new one !!
    i guess i need to go back to the dealer and ask them to do it again see if they actually do it this time
  1. Ncdc 2013 radio safe
    By jodiexii in forum Electrical & ICE (including SatNav)
    Last Post: 3rd November 2012, 19:27
  2. NCDC 2015 display safe
    By stewartg1 in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2012, 09:34
  3. ncdc 2013 radio safe
    By thecarlotz in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2012, 11:58
  4. Ncdc 2013....safe mode
    By bigcarman79 in forum Electrical & ICE (including SatNav)
    Last Post: 6th February 2009, 20:44
  5. NCDC 2013 sat nav
    By Dwabo in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2008, 21:32
how to enter code on ncdc 2013
how to enter safe code ncdc 2013
ncdc 2013 code entering
display safe ncdc 2013 opel vectra c
