Thread: vectra 2.2 auto problem
    coventry
    Default vectra 2.2 auto problem
    i have a 2002 vauxhall vectra 2.2 automatic, ii had the problem with only getting 2nd and 5th gear, but cured that buy changiing the oil. now i loose all my drive when the engine is hot! if i switch the ignition off and back on again it cures the problem for about 1 mile. is there some kind of gear box cooling problem with it?
    if it resets when you turn off the ignition, it sounds more like an electronic fault..
    i doubt it's a coolant fault.. more likely a sensor breaking down with heat shunt..
    what it needs is plugging in to a GOOD diagnostic system.... that will be a great start
    coventry
    any idea where these sensors mjght be located mate? cheers
    take your pick.... they are all over the gearbox....accurate diagnosis is needed first to see exactly what the problem is before just blindly changing parts on the box..
    coventry
    so i can still get an electrical fault without having any warning lights appear on my dash?
    Stamford Lincs
    Hi Mate, I've the same car with the same series of faults. The set when it keeps defaulting to limp home mode require 4 attemps and £450 at my very unhelpfull main dealer and over 3 weeks. They ended up changing 2 main sensors on the box. After each attempt they rang me and told me it was fixed.
    Its now lost drive until its turned off and restarted, it then drives ok until i stop, then no drive again until i turn it off and restart.
    Have you sorted yours now? If so what was the problem?
    The new main dealer has` just told me its a new box and £3.5K!!! That just aint gona happen on a £3K car is it
    And help greatly appriciated.
    costa rica
    well I do have exactly the same problem and all I can get from the "experts" is that the auto transmission speed sensor needs to be replaced :-(. Anyone that did this and worked out????? Mine is a 2003 model vectra 2.2 sold under Chevrolet in latin america.
    costa rica
    buy the way I need urgent help on this :-)
    essex
    Default sensor
    I changed the turbine speedsensor one is on the top of the box which is input .I changed the output which is the same sneakely hidden on the right side of box under battery, pig to change and now cured!!
    Yorkshire
    Quote Originally Posted by popinoz View Post
    Did the old one have crud all over the end when you changed it? If so its probably a tempory fix as the crud is the metal from the friction plates and it sticks to the speed pickup sensors and provides false error codes.
  1. 2.2 vectra c auto gearbox problem
    By Paddy in forum Engine & Drivetrain
    Last Post: 12th March 2011, 18:54
  2. Vectra 2.2 Auto idle problem
    By colinstar in forum Engine & Drivetrain
    Last Post: 11th March 2011, 19:31
  3. vectra c auto problem
    By popinoz in forum Engine & Drivetrain
    Last Post: 3rd July 2010, 21:15
  4. 1.9 Vectra cDTi auto Gearbox problem
    By matthunter76 in forum Engine & Drivetrain
    Last Post: 23rd September 2009, 13:53
  5. Vectra 52 (2003) 2.2LS + Auto box problem
    By sloath in forum Engine & Drivetrain
    Last Post: 26th September 2007, 15:00
vectra c 2.2 auto problem
