Results 1 to 10 of 14
Thread: vec c 2.0 dti
    May 2008
    fife
    Default vec c 2.0 dti
    hi iv got no glow light on the dash any ideas as to wot the problem could be
    Portadown, N.I.
    There prob is no problem, I only see the glow light in my 2.0Dti when the temp has got below zero overnight, and even then it would be only on the 1st start of the day.
    I think that the 2.0Dti engine has got good enough compression to start without needing the glow plugs for each start.
    Tim
    Regular Member dan9895's Avatar
    Apr 2008
    exmouth devon
    yer mines the same vauxhall told me the glowplugs will only kick in when its below minus 5 (-5c) so the likely hood is you may never see it
    unless winter is really cold
    but it shouldnt be anything to worry about unless your having a problem that you assumed was glowplug related??
    vauxhall told me how to force the glow plug on if you would like to know how but i will have to upload some piccies to show you.
    they told me that this practice of glowplug charging was standard across the dti range
    Hope this helps!!
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    As a vec 2.0 DTI owner for the past 8 years (b & c), the only time the glow plug light will come on is when the outside temp is below 2oc
    West
    Quote Originally Posted by SteveH View Post
    Steve are you sure about this because i'm sure my pre heater light used to come on under 10*c, although it's not comming on now & it's chugging to life in a morning just lately
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Mine has never been on,since ive had her but just recently last 2 times ive tried to start her in the morning she's been a bit lumpy on startup then after 10 secs clears and runs fine,bit of smoke too
    Regular Member John3v36's Avatar
    NI
    Hope this helps!![/quote]
    wouldnt mind posting a few pics up, id like to see how it is done!! thanks
    West
    Quote Originally Posted by dan9895 View Post
    Hope this helps!!
    yes this procedure would be interesting to know
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Hope this helps!!
    I would like to see this please..
    Regular Member addyboy1982's Avatar
    Northampton
    Mine comes on for a split second most mornings and then fires up without a problem, but if its a warmer morning the light doesn't show at all. I wouldn't say you have a problem
