Results 1 to 5 of 5
Thread: parrot ignition live problem
    Regular Member nick-v2.2's Avatar
    Nottingham
    Default parrot ignition live problem
    Hi, recently installed my Parrot ck3300 with help from members on here.
    I used the ignition live from the cigarette lighter,
    Now neither the parrot or ciggy light seem to have power, i'm guessin theres a fuse for this,
    could someone please let me know where it is.
    If there isn't a fuse, any ideas what it could be.
    Many thanks
    Nick J
    Technical directors office
    side fuse box, number 22.. it's a 30 amp mini blade fuse....
    open the passengers front door and pull the trim panel off the end of the dash..it reveals a small fuse box..
    Nottingham
    its a 30amo fuse
    how would a parrot blow a 30amp fuse.
    I havent even used the ciggy lighter
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    You might have to reverse to power wires on the parrot. Just unplug the two parrot fuse holders and plug the mate fro one into the female from the other. I had to do this with mine.
    Nottingham
    my ignition feed orange wire is connected to ciggy ignition feed now.
    I tried swapping them over, but the parrot just turned straight off instead off saying goodbye.
    It did work fine, i think its just the fuse.
    is 30a Mini a kight green?
    regards
  1. No ignition live please help
    By foxyland in forum Vectra C / Signum Troubleshooting
    Last Post: 12th December 2012, 22:49
  2. Wiring an amp, need an ignition live and permanent live in the boot
    By inchy1981 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 16:36
  3. Alternative ignition live for Parrot to work when engine off, but key still in?
    By Thomza in forum Electrical & ICE (including SatNav)
    Last Post: 10th August 2012, 05:06
  4. ignition live
    By Nessy in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2012, 19:23
  5. Ignition live
    By dazza3674 in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2011, 20:46
parrot ignition problems
