Thread: 2.0 DTI Water Temperature? Running cool?
    Regular Member StephNET's Avatar
    Wiltshire
    Question 2.0 DTI Water Temperature? Running cool?
    Am curious as to how the temperature should normally be on the 2.0 dti. Mine takes around 15-20 miles to come up to the mid 80s. Rarely gets warmer than that on cooler days. On warmer days I does come up to slightly over 90* but only on a long fast run, and the temp drops off as soon as I slow down. Sound like a shot thermostat or normal? Fans don't seem to come on very often. In normal driving in the 60mph range it fluctuates around 80-85ish.
    Also I had some quotes for a new thermostat, and they've all being around 50 quid and higher, citing the thermostat is part of a housing. Is this correct?
    Its a 54 plate 2.0 DTI.
    Thanks in Advance
    deffo sounds like the stat is duff...
    those prices?.. is that main dealer or OEM quality aftermarket like QH?...
    Wiltshire
    That was aftermarket, (Camberly Auto Factors)
    Wiltshire
    Does the engine temp normally stay fairly consistant?
    Regular Member dan9895's Avatar
    Apr 2008
    exmouth devon
    sounds just like mine,
    mine stays fairly constant temperture around 80 - 85
    does take a while to warm up aswell but there is nothing wrong with mine,
    what your describing is exactly what mine does
    if it aint broke dont fix it,
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Quote Originally Posted by dan9895 View Post
    Me too.
    I think its normal.
    Regular Member addyboy1982's Avatar
    Northampton
    Same here, mine is up to 80 after about 4 miles, then sits at 80-85 unless I'm stuck in traffic for ages
    East Midlands
    Mine is just the same..think its a characteristic of the car though..i'd leave it if i was you.
  1. CDTi 150 Running Temperature
    By tony-1977 in forum Engine & Drivetrain
    Last Post: 28th March 2012, 11:38
  2. coolant running temperature?
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2010, 13:24
  3. Running Temperature 1.8 vvti SRi???
    By bigrory1986 in forum Engine & Drivetrain
    Last Post: 14th September 2009, 14:07
  4. Cool Running Thermostat...
    By vauxhall4life in forum Petrol Engine related
    Last Post: 28th February 2008, 12:33
  5. Cool running thermostat
    By Spikey© in forum Petrol Engine related
    Last Post: 13th December 2005, 20:31
