Results 1 to 10 of 14
Thread: Steering heavy HELP !
    Regular Member cpt slow's Avatar
    In a house
    Default Steering heavy HELP !
    Just had a steering rack put on my car . as the original had play , anyway got the car back and now the steering feels heavy (ish)...not as light as what it was, and also the steering light has come on the dashboard with an exclamation mark .....!..... If the garage have fitted a rack that has stiffens up at speed , can it just be re-programmed via tech 2 .
    Or do all Vectras steering stiffen up at speed ?
    Please help me .
    Regular Member 2ltrT's Avatar
    North-East (Middlesbrough)
    mine stays the same regardless of speed,,,,, sounds like there is a problem there.
    In a house
    Garage told me that the ECU needs to read the new rack via Tech2 ?
    Regular Member Ozz's Avatar
    Sydney, Australia
    Your Veccy C steering will lighten up at low speed, parking etc & firm up (a little) at higher speeds.
    Might seem a silly question, but is there enough power steering fluid in the resevoir?
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Silly one but has the fuse blown? They are electric pumps on these are they not?
    In a house
    fuse is fine
    Melbourne, Australia
    Perhaps the steering angle sensor needs to be calibrated. (I think)Cars with ESP have the steering angle sensor incorporated in the Column Information Module (CIM); cars without ESP have the steering angle sensor as part of the steering rack. If the steering angle sensor hasn't been calibrated then the car probably doesn't know how much power assist to give.
    Just a guess...
    In a house
    my steering used to be light around town , but stiffen up on the motorway. Now its stiff all the time , some power steering there but nowhere near as light as it should be .
    In a house
    Sorted now . Thanks.
    Quote Originally Posted by caprimanuk
    What (if anything) was the problem please caprimanuk?
  1. very heavy steering
    By GCusdin in forum Suspension, Wheels & Brakes
    Last Post: 4th December 2012, 19:10
  2. Heavy steering intermitent
    By craigbarlow18 in forum Suspension, Wheels & Brakes
    Last Post: 2nd August 2010, 00:32
  3. Slightly heavy steering
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2009, 09:55
  4. Steering is a little heavy and juddery
    By freshprince in forum Suspension, Wheels & Brakes
    Last Post: 27th August 2008, 10:56
  5. Steering is a little heavy and juddery
    Last Post: 21st August 2008, 11:57
vectra c power steering heavy
