Results 1 to 10 of 21
Thread: Cim ??
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Default Cim ??
    following my original post here
    http://forum.vectra-c.com/showthread.php?t=54530
    been into vx to have the power steering light reset and the have phoned saying the CIM module needs re calibrated and should be done whenever steering is touched. i.e new pump fitted. Is this correct.. £68 to have it done.
    Any help would be appreciated
    Steve
    Re-calibrated? never heard that before???
    you have to set the steering angle sensor..
    can't see it needed being done when the pump is replaced.. it's normally programmed when the CIM is reeplaced as part of the CIM setup procedure, so the angle sensor in the CIM knows when the wheels are pointing straight ahead..
    also, following on from your earlier post.. it looks like as they were using a laptop it's VAUXCOM they used not TECH2.. TECH2 is on it's own 'pendant' not a laptop..
    Only the very latest releases of vauxcom can program the CIM.. is it a VX dealer it's at?...
    So unless they have had the CIM off it shouldn't need doing?
    i'd be surprised that a pump change means it needs reprogramming.. i'm certain that Glynn has never had to have his CIM reprogrammed when he's swapped pumps ( ans he's done a few)..
    if it's not a VX dealer i think i know whats going on....
    i wonder if they have tried to diagnose it with VAUXCOM.. got it wrong..swapped the pump over.. still got a light on but now can't find the fault.. so are trying to get a dealer TECH2 check paid for by the client....
    Yeah, the £68 is close to a quick tech 2 session......
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Never had to program the Cim when changed pumps a few times on my old saloon when is was first being put together. Think it maybe that the old pump had the oil level indicator and the new ones (replacements) no longer have them. This has to be tech2'd out otherwise the light will show for low fluid. Easy job to do so do not know what VX are on about having to reprogram the cim
    Nov 2007
    sounds right ... no it wasnt a vx dealer and they said tehy couldnt find a fault but couldnt put the light out... now its at vx and they said the angle sensor needs re calibrated.. and its 1 hrs labour on tech 2... so what exactly have the non vx garage done..?? thanks again
    I'd say nothing, they want to charge you for a tech 2 session at a vx dealer to reset the light.
    edit:just read your other post. Not sure what they have done apart from change the pump
