Results 1 to 10 of 23
Thread: 17"OZ Super trismos
    Regular Member BIG NEIL's Avatar
    Oct 2007
    Back in Belfast!!!!
    Default 17"OZ Super trismos
    was thinking of buying these and putting on the siggy just wondering will they fit ok ? and my siggy is a design and i was wondering will the look to small with the design standard suspension,the tyres are 215/45 17 and offset 5x110 5stud
    http://i98.photobucket.com/albums/l2...hammer/001.jpg
    Full Member Big Sig's Avatar
    Depending on the offset and hub size they will fit. What did they come off?
    I have always loved those wheels.
    Edit: forgot to add, as yours is a 3.0cdti you really should be thinking of running XL tyres. The size on those is a bit off too, but not too far.
    Oct 2007
    Back in Belfast!!!!
    they came of a vectra B GSI
    They wil fit ok then, just be a bit careful of the load rating on the tyres. A manual 3.0V6 is "just" ok on 91W's. the auto needs the XL rated as a minimum.
    Oct 2007
    Back in Belfast!!!!
    yes mine is manual ,what about the size of the wheel and tyre with the standard design suspension will it look to small
    cheers for the info sofar Big Sig
    The size is nearly the same as the origional ones. They will look smaller and your speedo will be out due to the fact both the tyre width and sidewall is smaller than it should be. The sidewall height is a percentage of the tyre width. There is a calculator on here somewhere that will tell you how far out it is.
    EDIT: correction, the tyre size isn't too far out as the oe size is 215/50/17 and your looking at 215/45/17
    Your speedo will read 3.3% too fast, it will read 60mph when your doing 58mph - so not too bad. The sidewall is 10mm lower in height.
    http://www.miata.net/garage/tirecalc.html
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Considering that you can have 225/45/17 fitted the tyres on the new rims should be ok speedo wise (they will not be out that much). I think myself that if I had a 3.0l I would want 225 or better still 235 tyre widths. Whats fitted at the moment?
    Oct 2007
    Back in Belfast!!!!
    there is 215/50 17" 91w on at the moment. that is the standard rim size
    Regular Member yorkiebar's Avatar
    Jun 2006
    N.IRELAND
    get them on big lad they look well break out and spend a few pounds
    You could swap the tryes over too
  1. anyone know any super super bright t10 side lights???
    By rozzer2006 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2012, 22:50
  2. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  3. worried!!!! have you ever used "corsa centre" or "supernovas"
    By vectra_c_wannabe in forum The 'Off Topic' room
    Last Post: 20th May 2009, 15:21
  4. Super Unleaded in a 1.8
    By @ndy-e in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2008, 12:12
  5. Super SRi!
    By Greg R in forum Introduce yourself.
    Last Post: 29th May 2007, 09:32
