Results 1 to 10 of 23
Thread: Cold Starting glow plug query
    West
    Default Cold Starting glow plug query
    Well today was the first cold morning for a long while, the out side temp was 10.5*c, the glow plug light did not come on as it hasn't all summer, the car failed to start with the first turn of the key but did start on the second, does any one know the max temp for the glow plug system to kick in.
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    IIRC Its 3 degrees
    Full Member Big Sig's Avatar
    My glow light comes on everytime I start the car, just for different lengths of time.
    West
    hmm mines 2.0dti whats yours
    3.0V6 CDTi, but the glow plug sequence should be the same i would have thought?
    Essex
    Sopposed to be around 3c
    But you'll find everyones is different
    sometimes my old vec would come on at 5 / 6 / 7 or sometimes not at all..
    It takes the engine temp reading from a coolant sensor near the temp gauge sensor, in the thermostat housing, check that first.
    ( i gave in in the end with mine a rewired it to have a manual glow plug switch)
    Mike
    May 2006
    scotland
    Same here. One mild days the light goes out after 1 second or so. On cold winter days, 3 or 4 seconds.
    Regular Member LJ sxi-nav's Avatar
    Winchester
    unless the car has been used upto a few hours ago, or outside temp is warm i.e. plus 20'C
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    mine comes on every time i start the car first thing in the morning in the warmer weather not for very lond at all 1.9ctdi
    In my 3.0 V6 CDTI the glow plug light comes on for about 2 seconds when the engine is cold and typically between 1/4 and 1 second when the engine is hot or warm
    The manual does not even advise that you need to wait for it, it is just to show the system is in operation
    It may also come on if your car has a DPF, in which case it will flash
  1. No Glow Plug Light. Help!
    By M65 in forum Engine & Drivetrain
    Last Post: 4th December 2012, 18:25
  2. Fault code readers, EML and glow plug query
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 19:44
  3. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
  4. glow plug
    By dominic32 in forum Engine & Drivetrain
    Last Post: 6th July 2009, 21:46
  5. 2.0 DTi Running cold and no glow plug light..?
    By olid2002 in forum Diesel Engine related
    Last Post: 27th May 2009, 22:46
