Thread: Servo pack / Heater / Relay - How annoying!
    Jan 2008
    West Wales
    Default Servo pack / Heater / Relay - How annoying!
    All,
    How are we?
    I hope you can help with this annoying but prob simple issue.
    Following a long drive in heavy rain (Rain in August - who would beleive it...) i have annoying problem.
    I get clicking - relay noises when floating over to a/c or recirc. Initally I thought it was gearing problem on the aircon fan as that's when it started but now... it seems the car is doing it a lot even when not driven, get that! especially when opening the car if standing for more than 15mins - and seems to do it every 15mins or so if the car is just standing?
    I can't explain this
    The car is the Elite (05) so has dual climate control - not that that seems to make a difference - warm or cold air seem to come out and fan runs fine 1 - 7. Can't pin down what this could be.
    Checked the rain wells/drains around the pollen filter and all seemed fine, no wet floor.
    Anyone had this before - would the car know if the recirc/outside flap was incorrectly aligned - does it do these kind of checks when firing opertaing the key fob? I can't explain it.
    Really need so advice - as far as I can tell - once the car is running the clicking does not happen unless I engage the a/c (sometimes) or when I swtich from recirc to outside and visa versa.....?
    Is it ghosts? or Gremlins?
    Rgs
    Bobby
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    That's exactly the same problem mine has (and a few others), it's the recirculation servo for sure. I'd managed to ignore mine for a while but it drove us crackers while camping the other week. I ended up setting it to fresh air then disconnecting the noisy thing.
    It's the topmost servo of the three, the most difficult to reach and means the fascia trim has to come off then removal of the glove box. A new servo is around £60, so I've been told.
    Regular Member m_r_shaw's Avatar
    Sunny Waterloo, just outside Liverpool.....
    same here, when i switch the ignition on, i get a series of 18 quick clicks, and been told it's the recirc unit!!!!
    Jan 2008
    West Wales
    Well at least I am not alone in my annoyance.
    The clicking is happening every 3 1/2 mins when the car is locked up!. Auto recirc is turned off (air quality) so why would this thing servo be trying to work while stationary - it seems to work when driving - as in recirc - but when manually turning recirc on and off it also clicks - but different clicking...
    Might have to disconnect short term as I do not want the battery going flat or burning out etc....
    Is it dangerous?
    Rgs
    Bobby
    Jan 2008
    West Wales
    Default Right.
    I have found the clicking noise.
    After removing the glovebox and looking up behind it it seems the recirc motor is attached the main fan... is this correct?
    Following unplugging the said motor the clicking noise has gone all the time.
    See pics
    Is this the recirc motor and as it looks hard to replace is it straight forward?
    Rgs
    Bobby
    Oh.... and.... is the motor cover now in the none recirc postion - I think it is?
    Those are fairly cheap to buy, not sure how easy they are to replace, more fiddly than anything I would imagine. Looks like the recirc servo motor to me
    Trim : GSi
    Mileage : 39k
    Yes, that's the servo that's the problem and yes, from the looks of it, the flap is in the closed/recirc position.
    I'm not even sure if (for me) it's worth the hassle/expense to replace; I've never needed to use the recirculation button/switch on any of my previous cars and have never used it on this one.
    The only time I may need to reconnect it (as mine is left in the fresh air position) is if I ever need to use an aircon bug bomb thing.
    Quote Originally Posted by AntB View Post
    When you put the temp to "lo" it closes that flap. I know what your saying but it would bug me knowing it didn't work!
    May 2006
    scotland
    If the air con is on and you have the heater blower full speed, it automatically goes into recirc mode, ie. the flap closes. I checked this when I was chaniging the pollen filter and sure enough thats how it works so even if you never use the recirc switch, if you are in the mode described above, it will close the flap.
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    i had the same problem, clicking when getting into the car
    i told the dealer & they replaced the recirculation motor under warranty
  1. Heater Servo Ticking
    By ed taylor in forum Bodywork & Interior
    Last Post: 7th November 2012, 10:26
  2. Heater flap servo
    By ed taylor in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2011, 21:21
  3. Heater Blower relay
    By mo-mo in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2010, 13:52
  4. heater mixer thingy servo
    By toast in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2010, 10:49
  5. Servo pack body fault codes
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2008, 20:38
