Thread: 2.2 idling
    Regular Member old cruiser's Avatar
    slough
    Default 2.2 idling
    Anyone with the 2.2; how smooth do you find the car idles, I don't find mine is particularly smooth as such , having said that it doesn't misfire as it were it's just that you can feel it through the seats if you know what I mean and notice it more after about 10 secs or there abouts after I come to a stop, my last car was a Focus and with that you couldn't feel anything on idle so much so that sometimes I thought it had cut out!! as it was so smooth, other than that these Vectras are quite a joy to drive it has to be said!!
    Cheers Pete
    Jul 2006
    Mexico
    Have you check the idle valve being clean mate?
    Or the plugs?
    slough
    Good point mate, did plugs, throttle body clean out, air & fuel filter change, but didn't think about the Idle valve as I thought it was purely governed by the ECU on these, so it has got this vlave then?
    Cheers Pete
    of sorts... it's all part of the throttle butterfly.. if it's clean then it will help no end
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    You could also check you have no air leaks on any vac hoses and mounting point of the TB?
    Regular Member Matty H's Avatar
    Bristol
    My car is new and is the same. As you say, it doesn't misfire, you can just feel the odd very minor burble in the tickover
    slough
    Cheers guys , the more I think about it my old Omega 2.2 I had before the Focus I think was a bit like this, but with the Omega I seem to remember you could see the Tacho needle fluctuating also , whereas on the Vectra needle is well steady.
    Cheers Pete
    Vehicle : SRi
    Mileage : 137000
    The Omega was a x22se not the z22se that you have now.
    Regular Member Vid's Avatar
    May 2007
    In the inventing shed...
    I would agree that the problem is likely to be the throttle body.
    Get it off and get it cleaned.
    slough
    Already did that mate and didn't make much difference
    Cheers Pete
  1. lumpy idling
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2011, 15:56
  2. Idling issue
    By Matt Cutler in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2011, 20:39
  3. Idling Cars
    By Dezza in forum General Chat
    Last Post: 2nd December 2008, 22:41
  4. Idling
    By Daywalker in forum Engine & Drivetrain
    Last Post: 10th May 2008, 08:23
