Thread: Spark plugs
    Regular Member PeteRs's Avatar
    here or there
    Default Spark plugs
    got an SRi turbo here 3 plugs are sooty/black indicating running too rich 4th plug is normal colour it does run lumpy on tickover is there a fault somewhere causing 3 cylinders to overfuel thanks
    there could well be a fault concerning the 3 'sooty' plugs.. there are 4 injectors after all..
    no management lights???
    Are the plugs dry and sooty or wet and oiled?..got a pic of plug condition?..
    here or there
    there dry & sooty no engine light on appears to run ok apart from lumpy tickover thanks
    it could be failing coils packs ( failing to ignite the plug every spark)... does it pull well or does it hesitate up the rev range?..
    here or there
    got a pic yes its got a flat spot then takes off
    and those plugs are like that, fresh out of your new engine?...
    here or there
    no its my sons car hes just bought it i got an diesel cdti problay why it keeps breaking
    Ahh.. didn't think you had a petrol.....
    things that make them run rich..
    1: induction kits... play havoc with the fuelling at low rpm's..
    2: lambda sensors.. but i would expect all 4 to be equally sooty
    3: weeping ( dribbleing injectors) allowing fuel past when they should be closed
    4: breaking down leads/DIS coils..
    has it had an emissions check to see what the idle mixture is like.. i.e. is it overfuelling or just not burning what it's got correctly...
    here or there
    he just bought it this morning but wanted me to service it & this is what i found when taking them out car is an 05 reg with 54000 think we'll get it checked out at garage as it dont seem right thanks
    i have pulled the HT leads off when engine running 1 & 3 engine runs still ok 2 & 4 engine cuts out dont know if this means owt
    what car is it?...vectra C?
  1. 3.2v6 best spark plugs to get?
    By PANDY 3.2 V6 in forum Petrol Engine related
    Last Post: 14th February 2012, 02:15
  2. Spark plugs 2.0T?
    By Steven in forum Petrol Engine related
    Last Post: 24th September 2011, 16:43
  3. Spark plugs
    By telstar in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 20:36
  4. spark plugs
    By Morephun in forum Engine & Drivetrain
    Last Post: 1st October 2008, 06:37
  5. Spark plugs for LPG
    By Gavin1977 in forum Engine & Drivetrain
    Last Post: 3rd December 2007, 09:17
