Results 1 to 10 of 15
Thread: Windscreen leaking??
    Jan 2006
    Skynet HQ EMEC#5
    Default Windscreen leaking??
    After last night's heavy rain, I've noticed this morning that a very small amount of water is getting in.
    It's down near the kick panel, driver's side.
    It's not vast amounts, but over time would get under the carpet.
    I don't think it's the bulkhead area, as I keep the drain rubbers clear.
    Could it be a leaking windscreen, or has anyone else found problems??
    Full Member Big Sig's Avatar
    Ian, my windscreen leaked down the passengerside as the seal had failed. The garage re-sealed it for me but not sure how much this should cost.
    Jan 2006
    Skynet HQ EMEC#5
    Would it be worth removing the plastic trim down the side of the screen to check?
    If so, does anyone know how the trims are removed?
    Don't know if you would see anything. I think the strips are clipped on but don't quote me on that! Maybe get on your back in the footwell with a torch and let the little ones loose with a hose?
    trims are just clipped on.....
    Ian. run a hose over the screen edges to see if it leaks through..if it does, then you can buy a screen sealer liquid...
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Have u had a replacement windscreen as it may still be under warranty
    Jan 2006
    Skynet HQ EMEC#5
    Quote Originally Posted by merikiito View Post
    Not that recent, has been over 2 years
    How easy is it to remove the panel under the steering wheel / above pedals?
    It'll give me a better view of the problem.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by Ian T View Post
    Should be just a few torx screws I think
    Jan 2006
    Skynet HQ EMEC#5
    How is the 'A' pillar trim removed?
    Just wanting to get a better view of the problem area
    Jan 2006
    Skynet HQ EMEC#5
    Well, removed all the trim earlier to see if I could locate the leak.
    Poured water over the edges of the screen.............no sign of it leaking
    Now where??
  1. Sig still leaking.......
    By wilky3720 in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2012, 16:49
  2. air leaking
    By elite150 in forum Diesel Engine related
    Last Post: 24th March 2012, 17:18
  3. leaking windscreen.
    By supersteve_75 in forum Bodywork & Interior
    Last Post: 1st August 2011, 23:44
  4. oil leaking...
    By danman487 in forum Engine & Drivetrain
    Last Post: 6th September 2010, 08:01
  5. Oil leaking from somewhere.
    By jayd in forum Engine & Drivetrain
    Last Post: 10th April 2008, 20:50
leaking seals around windscreen on 2007 vectra
how to remove a pillar trim vectra c
