Thread: Vectra C 3.2 V6 Elite Aircon problem
    Jun 2007
    Edinburgh
    Default Vectra C 3.2 V6 Elite Aircon problem
    Can anybody throw some light on a problem I am having. I had the dreaded water in the drivers footwell problem related to the blocked scuttle drain. Problem now is I cannot get the blower to switch off even when the ignition is off, I have to remove the fuse. Anyway I have just had the Vaux Com on the vehicle and it states "No feedback from blower" so I assume the electronic aircon system has a feedback sensor. The air conditioning system did ramp down when reaching temperature (when it was working correctly that is) so I can only assume there is a sensor somewhere, but I cannot find it. I have read posts about the resister pack fault but I think this just relates to systems that are switched, e.g 1-4 on the switch. Also googled every combination of sensor blower etc but just getting nowhere. Obviously something has water damage somewhere on the aircon system. Anybody help please.
    Full Member Big Sig's Avatar
    I would have imagined it would be the resistor in the motor control that normally gets wet when the drain is blocked. Anyone else?
    Jul 2006
    Is the sensor not that little black dome at the front of the dashboard, sitting on top of the centre speaker grille?
    Quote Originally Posted by parapaul View Post
    forgot about that one
    Jun 2007
    Edinburgh
    Thanks guys, will check that out.
    Seems that when in automatic mode the blower does ramp up and down but this is related to temperature. When taken out of automatic the blower ramps down to 50% of its speed and doesnt react to the dial, e.g when on zero it is still on. What I cant understand is why it is on with the ignition of. I assume this is because you are able to have the system on residual heating with the ignition off. What I would give for a manual.
    The manuals are downloadable from the VX website although I am not sure of the exact location, I do know you need to login to do it - free for anyone to do.
    Mine had a problem with the heaters fan speed when I first had it, the vx garage replaced the control module - it had to be tech-2'ed to the car I seem to remember.
    Jun 2007
    Edinburgh
    Found this excellent piece from a book whilst searching the web if anybody is interested.
    http://books.google.co.uk/books?id=b...sult#PPA235,M1
    Jun 2007
    Edinburgh
    The book looked so good I bought it off Amazon.
    It has a case study on the Vectra C air con system. Now think its down to the blower motor regulator which is situated under the motor (Great pics in the book)
    Anyway stripped it out and found slight water damage inside. So I am sourcing the part tomorrow and pray I am right.
    Took some photo,s and I will post them to this thread if I am successfull.
    hunstanton norfolk
    Hi I Having The Same Prob Took Out Regulator Water Damaged Vauxhall Want £135 For Part Did You Sort Yours Out Regards Gary
    Jun 2007
    Edinburgh
    Quote Originally Posted by garyedward123 View Post
    No not yet. However Vauxhall want £200 for mine has you cant buy a regulator for the Auto aircon and have to purchase the whole blower.
    You need to check if yours is autoaircon has the vectra c with the 3/4 position switch is a lot easier to fix I believe by replacing a resister in the regulator. There is a thread about it on this site somewhere. Otherwise try ebay search by "vauxhall vectra breaking"
    Hope this helps.
  1. Aircon problem?
    By Mads in forum Engine & Drivetrain
    Last Post: 5th September 2012, 22:58
  2. strange AIRCON problem
    By sthomson1 in forum Troubleshooting
    Last Post: 27th February 2011, 17:42
  3. Aircon dial problem
    By fastcarmanaic in forum Troubleshooting
    Last Post: 7th December 2010, 10:22
  4. can aircon problem put eml light on?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2010, 20:39
  5. Aircon problem
    By RN37 VXL in forum Troubleshooting
    Last Post: 24th January 2010, 05:19
vectra c 3.2 v6 problems
vectra c aircon turns off when lights are on
intermittent starting problems with vectra c 3.2 v6
