Thread: Air vent removal middle and top of dash.
    bristol
    Question Air vent removal middle and top of dash.
    somehow a coin has fallen I think into the air vent on top of the dash, everytime I go around a corner it annoyingly slides from left to right and equally annoyingly right to left. HELP!! any advice on how to get to it out before I go round the bend !!! I have sat nav and may need to gain access from the center vents either side.
    Surrey
    You got too much money. I am sure someone will come along soon with an answer.
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    If its the centre one, near windscreen then it just clips in, it looks like a vent grill but its actually for a speaker I believe, at least on mine it is, there's a connector in there with 2 wires.
    You should be able to spring it out quite easily.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Remove the coloured trim strip that runs along the front of the dash. This should pull off if you start at one end. Then you will see 4 torx screws relating to the centre vents. Remove these and the centre vents will pull out. Now find someone will small hands who needs money!
    The dash speaker is covered with a plastic vent which will just prise off. Problem then is removing the centre speaker as it is a pain as u can end up dropping the screws into the hole and then you will have two things floating about! Then I do not believe u can get to the tunnel behind as there is plastic in the way.
  1. Air vent removal
    By Jabbekot in forum Bodywork & Interior
    Last Post: 10th November 2010, 11:11
  2. how does middle dash vent come out?
    By pogo in forum Bodywork & Interior
    Last Post: 29th August 2009, 14:34
  3. middle vent and screen
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2009, 13:19
how do you remove centre heater. vents on vectra c
how to change vauxhall zafira front center air vent
vectra c central air vent louvre
how do you change a vent in a vauxhall signum
how so you change a vent in a vauxhall signum
bird chirps from vectra c air vent
how to remove dash trim vent on zafira
vauxhall corsa c air vent removal
vauxhall zafira 2009 how too remove centre vent cover
how to get middle vents out on a vectra c
vectra c center air vent removal
2007 vauxhall zafira remove centre dash
zafira b front airvent removal
can u remove the air vents in a zafira
how to remove rear air vents in Vauxhall Zafira 2009
zafira b remove top vents
how to remove zafira air vents
vectra c vent removal
vectra c vents removal
opel vectra c dashboard air vent grill
vectra c center vents removal
vectra c center heater vent removal
how to remove dashboard on a vauxhall zafira to repair air vents
How to take out vectra c heater vent
https:www.vectra-c.comforumshowthread.php56642-Air-vent-removal-middle-and-top-of-dash
