Results 1 to 3 of 3
Thread: Vectra 1.9CDTi Oil Change Query
    Mar 2007
    Attleborough, Norfolk
    Default Vectra 1.9CDTi Oil Change Query
    HI All
    My 55 plate Vectra is now out of warranty so I am looking to take it to a local indy for MOT and service. The car has been on the 20K flexi service and as I have been doing long journeys this has been convenient but possibly not a good thing. So with an oil change coming up I am weighing cost of a fill of 20K longlife oil and filter against 2X oil and filter every 10K miles.
    This has no doubt been discussed here before so apologies but can you give any idea how the costs compare and is it similar viscosity range of oil but normal against longlife?
    Thanks.
    Brian
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i belive the long life oil is for 18,000 miles and standard oil is for about 10,000 and i dont think the the cost is much difference HTH
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    I personally beleive the oil should be changed every 10k or 1 year (which ever is 1st) VX advise that as long as you use the GM longlife oil 20k is fine. for peiece of mind i use the GM longlife and have it changed every 10K or 12months... VX have said that if i was additional oil chnages and i supply GM oil they will do it if i buy the filter from them for about £40 plus my oil.. which seemed fair as they wanted over £40 for the oil!, half that on fleabay.
    So its your call... others use the 10/40 and change it every 10k and no one yet has had a major issue... i did say yet!.
  1. How often are you ment to change cam belf on vectra 1.9cdti 150?
    By shearzy in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2009, 20:08
  2. Interior trim replacement query 1.9cdti
    By teutonic in forum Bodywork & Interior
    Last Post: 31st July 2009, 09:23
  3. Gearbox oil change 1.9cdti
    By sigtim in forum Engine & Drivetrain
    Last Post: 27th August 2008, 19:22
  4. cam belt change 1.9cdti (120)
    By bigsteve in forum Engine & Drivetrain
    Last Post: 22nd August 2008, 17:16
  5. Cambelt Change On 2004 Vectra 1.9cdti Sri 150
    By PAULMAC77 in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2008, 11:24
vectra 1.9cdti how often change oil
1.9 cdti long life oil
What oil do I put in a 55 plate vectra cdti 1800
vectra c sri 120 oil change
what oil for 1.9cdti vectra zdti
cost of oil change on vectra cdti
