Results 1 to 8 of 8
Thread: pre facelift radio steering wheel controls
    Jul 2008
    aberdeen
    Default pre facelift radio steering wheel controls
    hi peeps can any1 tell me if the radio steering wheel controls on my 54 reg (the ones with the circles rather than the scroll buttons) pull straight off or do i need to remove the steering wheel & will the scroll buttons go straight on without any moddin..
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Should be a screw behind each one holding them to the wheel, undo those and then carefully tug on the switches and they should come off.
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    if you change the controls from buttons to the wheel im sure they will not work or at least thats what i was told
    Jun 2006
    Northampton
    Buttons from what I've read on here are half canbus cars and scroll buttons are full canbus cars.
    Aug 2006
    Is a very naughty boy
    Quote Originally Posted by vectragsi3.2 View Post
    Correct, they won't work. Its major hassle to do it and not sure anyone has bothered.
    Here, there and every where!
    Year : 05
    Won't work m8
    As has already been said, 3 buttons either side are half canbus and scroll wheels are full canbus.
    Jul 2008
    aberdeen
    will changing the wheel make any diff..not to sure what canbus is all about
    Year : 05
    Nope!
    If you have a half canbus car you cannot fit any full canbus parts.
    CANbus is the method the car uses to talk to various parts and is all done by ECU's sending signal rather than voltage to do the switching.
  1. Steering Wheel Radio Controls
    By j62k in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2008, 14:22
  2. pre facelift radio steering wheel controls
    By stewduff74 in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2008, 20:05
  3. steering wheel radio controls
    By pmw123 in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2007, 12:11
