Thread: can someone please help!!
    Regular Member ADAM123's Avatar
    Jan 2008
    UK
    Default can someone please help!!
    hi all, after fitting a set of after market black headlights to my car. my 'blown light bulb' warning on my speedo area of dash has lit up. there are no bulbs that have blown as i've checked, nor can i find a dodgy connection. therefore i was hoping if someone can tell me where abouts the fuse is. so i can remove it to stop the ****** warning coming on my dash. thank you kindly. adam
    Full Member Big Sig's Avatar
    There is no fuse to remove for the warning. Remove all the bulbs and give the contacts a good clean. Also make sure the multi-plugs have a good contact.
    Regular Member m_r_shaw's Avatar
    Sunny Waterloo, just outside Liverpool.....
    possibly if they are HID bulbs of LED's, then it will trigger the bulb out warning in the dash?
    LED's will, hid's normally flicker if they are a problem with the selfcheck. Not sure if they put it on or not actually. But as you have had them all out, I would expect a dodgy connection. A bad connection means high resistance. If its above a set value the computer will think its blown.
