Thread: 3rd brake light removal.?
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Default 3rd brake light removal.?
    Anyone...cant be assed to go look as its raining lol.
    Have a shody red one ...smoked to replace.
    thanks in advance
    Chris.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    you will need to prise it out carfully from the out side as its just held in by three clips
    Quote Originally Posted by glynn View Post
    Excellent...think we have some spec'd ones at work...may have to aquire
    Oct 2006
    southampton
    15 Post(s)
    if you try from the outside you risk cracking the light or even damaging your paint. done this change and removed the interior trim and did it from the inside. choice is yours though
    i tryed mine and it was in a boxed in section
    Oct 2006
    southampton
    15 Post(s)
    seen that mentioned before on here, mine was accessible from the inside of the tailgate.
    Think i will attempt from the inside to...dont want to paint anything else...unless i get somethings worth painting
    Regular Member stu28375's Avatar
    Jan 2008
    Colchester
    If you dont mind "mullering" the red one, which is what I did, just yank out from the outside (ensuring not to damage paintwork of course) then just pop new one in.
    May 2008
    Tyneside
    Did mine last month. If you have not got access from the inside after removing the trim panel, the vauxhall technical information sheet states you have to drill three holes in the cover to undo the bolts. When you look at the steel cover you can see three dimples marked on the panel where to drill. Use a 5mm drill and don't forget to touch up the edges with a little paint to stop it rusting. The bolts are 4mm hex key from what I remember, but if you have a new light it will be the same size. You only have to unscrew the bolts a couple of turns to release the clips. When I tried from the outside I had no luck and didn't want to chance damaging the paintwork.
    North West
    thats good advice that tridley i totally smashed my red brake light out with a small joiners bradall and chisel and screwdrivers endeed up in little pieces
    i put plenty of masking tape all round to make sure i didn't scratch the paintork around the brakelight
    wish i knew what u knewcould have put my red light on ebay
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Brake line removal
    By mparks8590 in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2010, 17:47
  3. brake light removal help
    By Ben_ in forum Styling
    Last Post: 2nd June 2009, 10:07
  4. 3rd Brake Light Removal
    By Baz07 in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2008, 22:36
  5. Brake Light Switch Removal
    By Mowster in forum Electrical & ICE (including SatNav)
    Last Post: 9th October 2007, 17:01
how to change 3rd brake light vectra c
how to replace third brake light vectra c 1.8
how to remove vectra c third brake light
