Thread: fan belt ??
    Regular Member arniedavo's Avatar
    merseyside
    Default fan belt ??
    fan belt squeaking ...
    2.2dti sri
    ... looks like gunna have to fit new one
    never done one before is it hard to do ??
    ok with mechanical things but had quick look an looks a pain to do
    any advice ..
    ...thanks in advance
    Bristol
    Vehicle : CDTI 150
    Remove the air filter box to improve access and note routing of belt.
    Either draw or use digital cam for ref if your memories anything like mine!!
    Jack up front and remove drivers side front wheel.
    Remove undertray.
    To the right of the tensioner is a hexagonal hole, you need an adaptor to fit.
    Then using a wrench or spanner on the adaptor lever the tensioner anti clockwise. This will release the tension on the belt.
    Slip the belt of and gently release tensionor.
    Fit belt, take up tension as above, slide new belt over tensioner and slowly release. Tension setting is automatic.
    merseyside
    ok fitted new belt today ...
    ...but when its under load ie drive off it still squeaks
    i checked all pulleys an they seemed ok
    any ideas
    Bristol
    Vehicle : CDTI 150
    With engine cold remove the aux drive belt.
    Worn bearing on any of the pulleys/alt etc. Rotate each pulley - check for uneven movement or sticking.
    Possibly grease/oil on any of the pulleys. Clean with a degreaseant.
    Could be a worn tensioner. Check by replacement. Vx can test for correct tension but will charge.
    Are you definate the noise is from the aux belt?
    You can briefly run the engine with the aux belt off if cold. Is noise still apparent??
    merseyside
    had belt checked by vauxhall technician ....
    he seems to think it`s an air leak ???
    checked all pipes but carn`t find anything ??
    any ideas
  1. 1.9 cam belt
    By J P S in forum Engine & Drivetrain
    Last Post: 18th February 2012, 12:13
  2. Belt changes on a 1.8 VVT
    By PeterVV in forum Engine & Drivetrain
    Last Post: 27th April 2011, 21:53
  3. Fan belt / Drive belt
    By patdavis in forum Engine & Drivetrain
    Last Post: 8th January 2011, 00:39
  4. drive belt or fan belt
    By geebee007 in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2008, 10:23
2.2 dti engine shanging fanbelt
