Thread: Couple of Problems :(
    Cornwall
    Default Couple of Problems :(
    Hi everyone
    Just bought a 52 plate 2.2 Petrol Vectra off a dealer with 31K miles, everything generally fine on the car, only thing is i have the car spanner light on when ignition on goes out when starting the car, i did have the service light on originally which i reset and this has been coming on since?
    Plus it's an auto and i'm hearing horror stories about water contamination and wonder if mine should be a recall? I don't wish it to happen to me!, I have spoken to a vauxhall dealer and it's only under a recall for radiator harness thingy? not sure what this means
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    take it back to the dealers m8 as it might need tech 2 as their might be a fault stored in the ecu
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    If it goes out when the car starts, isn't that just an historic fault code that'll clear after 25 restarts or so???
    BTW, that's an incredibly low mileage for a 52 plate!!!!!
    Cornwall
    Okay will get it checked out when it goes in for the recall, does anyone know what this rad electrical harness thingy is about?
    May 2007
    Can't find nothing on the recall re radiator harness. It's certainly not on VOSA's search engine for recalls
    As long as they are going to sort it, that's the main thing!!
    31K on a 52 plate...? No wonder you've got problems...
    Regular Member Andy17899's Avatar
    Jun 2007
    West Midlands
    Vehicle : Vauxhall Vectra SRI XPII
    Mileage : 68K
    Quote Originally Posted by Penfold101 View Post
    Mine had only 52K when it went and was fine..
    Cornwall
    what's that meant to mean??? Problems with it are not major
  1. couple of problems
    By CLOMP in forum Engine & Drivetrain
    Last Post: 1st April 2010, 19:51
  2. A couple of problems
    By Celes in forum Electrical & ICE (including SatNav)
    Last Post: 26th April 2009, 22:11
  3. Couple of problems with new car.......
    By pricey in forum Engine & Drivetrain
    Last Post: 12th August 2008, 17:18
  4. A couple of problems
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2006, 11:28
  5. hmm, couple of problems
    By Brake buster in forum Engine & Drivetrain
    Last Post: 26th July 2006, 10:27
