Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Washer Jets!
    Regular Member Netstar's Avatar
    Jan 2006
    South Wales
    Default Washer Jets!
    I once blocked them up by mixing the fliud up with too much consentrate. A mechanic mate of mine unblocked the lines and told me not to mix it so rich.
    So, when i refilled it that day i made up a batch of VERY VERY VERY weak wash (About one centimeter of consentrate in a 2 litre bottle!) and put it in.
    TWO DAYS later, blocked, AGAIN!
    Is this a common plroblem with Vec C's or something??
    And is there any easy way to clear it myself without going to the garage with my tail between my legs? "Ooops, i did it AGAIN! DUUUUR!"
    Could someone instruct me? I know theres an access point somewhere under the body of the front passenger side wing? Right????
    Please help!
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    I know on the Vectra B the rubber filter in which the motor/pump fits gets gunked up all the time.
    All you had to do was cut the end off it and no more blockages,
    Regular Member R-man's Avatar
    Beds
    I know this sounds madness but I use pure concentrate, I never mix with water, not least during the winter months. Never had a problem with that... you may just be unlucky..
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I never have a problem, and just put tap water in.
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    I had a similar problem with my old Zafira. The washers blocked up. It turned out to be some sort of algae growing in the tank which caused it all to fowl up - weird. Once Vx had flushed it through all was fine.
    May 2006
    Nottingham
    My vec b had three pumps fitted in the end by vx....that is 3 at the same time to stop it from blocking.
    SOMERSET
    I to have never had a problem, my mix is very strong.
    Regular Member Woodsta's Avatar
    May 2006
    Kent
    My washers started having very poor pressure and today they stopped alltogether!
    I accessed the washer bottle by turning the NS wheel into the wheel arch you can remove the 2 screws securing the inner wheel arch liner to the bumper, then you can get to the pump and pipes.
    i removed the pump and put it in a bucket of water tried it and it works.
    so the blockage was in the washer bottle. i removed the rubber gromet which the water pump locates in and found it was covered in a thick stringy blue mucas which must have built up over the past 75K miles. removed the sludge and also removed the washer level float switch further along the bottle, this again was covered. finally power flushed the bottle clean of any other contaminants.
    all parts cleaned and replaced now washers are better than ever.
    I wouldnt recommend cutting off the filters on the gromet as this would allow the sludge to travel around in the washer jet pipes and block those up!!!
    Woodsta
    pics of the clogged filters on the washer pump gromet
    SOMERSET
    Quote Originally Posted by PIMM View Post
    After this post only a few month's ago i had the same problem that you have had and what a pain in the bum. Done what you said and they are working fine but that blue stuff is like jelly
    I only use water from now on.
    May 2006
    Kent
    Your not wrong! right pain in the sigbum.
    Well worth the 30mins effort as VX wanted £69 just to have a look and recommended they fitted a new pump whilst they were there!!!!!!
    popped into the local motor factors and picked up some cheap screen wash pills, look like big blue smarties! no need now to measure out washer concentrate!
    The bug kill count on my car is amazing so i need a good screen wash!
    Woodsta
  1. Washer Jets
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2010, 17:20
  2. washer jets
    By rickeys16v in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2010, 19:32
  3. Are there any better washer jets out there..
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2008, 20:45
  4. Washer jets....
    By mc_orion in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2008, 17:59
