Thread: What is this Plug for?
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Default What is this Plug for?
    Vec C 56 plate 150. On top of the dash below the windscreen the centre plastic vent grill clips out to reveal a small wire loom with plug on the end protected by a bit of foam to stop it rattling. I think it only consisted of 3 wires.
    Any idea what it may have been intended for? Power feed for something maybe?
    do you have the sun sensor 'blob' on the top of the dash?....if not it'll be for the sensor....used with climate control...
    or..
    was there a speaker under the grille?...if not it could also be the plug for the Bass speaker..
    Apr 2008
    In UK
    or..
    No Blob whatever it is.. grill snaps in flush, and level with normal air vents either side of it.
    Just had another look and it is only 2 wires yellow and white, so more likely for a speaker perhaps, (There is no speaker fitted however)
    Came across it today when trying to locate rattle from dash, which I can hear if labouring a little in too high a gear.. IYKWIM
    it'll be for the bass speaker then..
    Regular Member monkeytwo's Avatar
    Camberley, Surrey
    Yep think thats it, in cars with the CD70 Navigation system in, a 7th /9th (depending on if you have rear tweeters) speaker goes in the middle of the dash (still flush) to give a spacial effect.
  1. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  2. preface gid screen plug, is it the same as the 32 pin vec b mid plug?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2011, 23:15
  3. plug
    By titley1976 in forum Electrical & ICE (including SatNav)
    Last Post: 1st June 2011, 22:14
  4. blue plug display into a grey plug vehicle
    By vxpenfold in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 23:09
  5. grey plug yellow plug?
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2010, 14:35
