Results 1 to 10 of 23
Thread: Upgraded Brakes
    Regular Member sycho666's Avatar
    Telford, Shropshire
    Default Upgraded Brakes
    Just a quick query...
    Im looking to get my brakes upgraded to the 314mm's. My question is about how much would I be looking to spend altogether, including the kit and fitting?
    Thank in advance.
    Regular Member shan's Avatar
    You can get the kit for 320 from LMF. Ask for a discount
    Not sure on the fitting side of things.
    Jul 2006
    Fitting will take less than an hour - any independent garage will do it for whatever their labour rate is.
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    What is actually upgraded with these kits, are the calipers replaced also.
    IOW whats in the kit? Thought about having this done myself, I know most of you have them for the looks, but I assume the braking efficiency is improved too due to the larger disc.
    you get the calipers, mounts and the disc's and pads....
    as well as the looks, they will seriously up the stopping power of the 285mm equipped cars...
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Braking is much better, you realise that as soon as you touch the brake pedal & they keep getting better with use so yes, they do look better, but for me it's the much improved braking that counts.
    and if 314's aren't enough to stop you.. there's always the 345mm VXR conversion..
    Regular Member bill1250's Avatar
    Apr 2008
    Hampshire, England
    what about those 314mm saab brakes everyone has
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    and they aren't disc on the car they are very large dinner plates (a mark)
    Winteringham
    got to say 314mm is massive improvement,
    fitted mine the other week took 20 Min per side very easy to do, now bedded in and all I can say is don't think about it just do it.
  1. VXR upgraded
    By bembo449 in forum Insignia car chat
    Last Post: 3rd December 2011, 19:45
  2. upgraded to 314mm brakes, now no pressure.
    By Mark_k in forum Suspension, Wheels & Brakes
    Last Post: 29th November 2011, 21:42
  3. upgraded
    By tonyv6elite in forum General Chat
    Last Post: 9th April 2009, 17:55
  4. Upgraded rear brakes
    By Mick B in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2008, 19:26
  5. upgraded brakes
    By aerodynamic18 in forum Handling & Braking
    Last Post: 14th September 2007, 21:37
