Results 1 to 10 of 17
Thread: How do I remove the light switch assembly?
    Northants
    Default How do I remove the light switch assembly?
    Hi, can anyone help me with removing the light switch assembly? The one with the rotary headlight switch. It appears that is must come out into the car, rather than pushed back through the panel. I've slipped a thin steel rule in along the top and bottom edges but I can't seem to feel any clips. I can't get anything in on the left and right side. I need the switch assembly out so I can get to the screw behind it that holds the trim panel on.
    TIA
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Press in the knob, turn to the right and then it just pulls out
    I think you need to turn it into the sidelight position and push the rotary knob in. It then releases it so you can pull it out. Its a bit tricky as I think you need to push the knob and pull the unit.
    Jun 2006
    Somewhere...
    Mind you when I first got mine the light switch just pulled out! Had to reseat it!
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    The catches are at the top and the bottom. Before I found out about doing the above I used 2 thin blade screwdrivers, its fiddly and works!
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Just keep pushing the knob in as you turn it. You'll soon get the feel of how it works although as said can be fiddly.
    Jan 2006
    Skynet HQ EMEC#5
    As said above, when switch is in off position, push the knob in & turn to sidelight position.
    You can then pull the switch out.
    When refitting, get switch assembly flush with dash, then turn switch back to off position. This locks switch assembly back in position.
    Regular Member ade's Avatar
    leicestershire
    hammer and screwdriver, or chisel
    Northants
    Eek
    Ok, I pushed in the light switch and turned it to the right, and it came out exactly as described, so far so good. Now to remove the trim panel I had to disconnect the blue connector from the back of the switch, no problem. Then I replaced the blue connector exactly as it was but now with the ignition off I can't get any lights. Worse still, when I turn the ignition on the headlights come on and I can't switch them off, whatever the light swith position is. I had the ignition switched off when I disconnected and reconnected the plug. Help !
    Northants
    Default Doh !
    Sorry, operator error, it's working now
  1. How do i remove a tc switch?
    By CraigoT in forum Bodywork & Interior
    Last Post: 19th December 2011, 22:51
  2. How to remove and replace hazard light switch?
    By barry087 in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2011, 15:48
  3. Head light motor assembly???
    By silver-tongue in forum Engine & Drivetrain
    Last Post: 21st December 2010, 16:51
  4. Front Fog light assembly
    By Markie68 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2009, 22:02
vectra c remove light switch
how to remove vectra c headlight switch
remove vectra c headlights switch
vectra c how to remove light switch
how to remove headlight switch from vectra C
removal of light switch vectra c
