Thread: grinding noise turning right
    Regular Member jon ixi's Avatar
    Mar 2007
    lisburn
    Default grinding noise turning right
    hi just noticed today that my car is making a rather bad grinding noise when the car is turning right this noise is visible at any speed but especially low speeds. the noise is coming from the front of the car. it isnt there when turning left. any help would be appreciated
    Regular Member m_r_shaw's Avatar
    Sunny Waterloo, just outside Liverpool.....
    maybe a worn c.v. joint?
    Mar 2007
    lisburn
    is that an expensive job, are they changed in pairs. it`s a really quite loud noise is there a check i can do myself before i take it to a garage. will it do any long term damage before i get it fixed
    Regular Member benny's Avatar
    Feb 2006
    dudley
    are your pads worn low ???
    Mar 2007
    lisburn
    no only 23000 miles on car but checked ands also no brake warning light on. is sound like two uneven pieces of metal rubbing hard together. also its a 3.0 cdti does the extra weight make them prone to any faults
    West
    The cv joint normally makes a clicking noise quite loud when its on it's way out & its usually the outer joint which goes, if it is the joint you are looking around £200 ish for the part, then prob an hour labour on top.
    Feb 2006
    dudley
    check for a broken spring mate
    Full Member Hummelshøj's Avatar
    Aug 2009
    Denmark, Kolind
    Vehicle : Vectra C OPC Estate
    Trim : OPC / VXR
    Engine : Z28NET
    Maybe backplate behind brakedisc´s is touching brakediscs.
    I have had this on my car.
    2006 Opel Vectra C OPC Estate Arden Blue 255bhp Heated full leather Climate control Full powerflex rear suspension Power tailgate Retractable Towbar Eibach 30mm Original BBS RS-GT 2-piece forged 20" with 225/35 front and 255/30 rear HID 5000K Autolights Rainsensor Dim rearview mirror Heat reflective windscreen 280bhp airbox mode Tinted windows PDC
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    Quote Originally Posted by Hummelshøj View Post
    I'm quite sure it's sorted mate, no offence, but it says these were posted in 2008!?
    Sep 2014
    Staffordshrie
    Engine : 3.0 CDTI
    Nice one for the advice though I've got this noise when turning left, will check that backplate later!
  1. LOUD grinding noise?
    By UncleMelon in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2012, 11:21
  2. grinding rubbing noise
    By coooky in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2011, 09:49
  3. knocking / grinding noise
    By Graeme in forum Suspension, Wheels & Brakes
    Last Post: 20th May 2011, 23:51
  4. brake grinding noise
    By li4m in forum Suspension, Wheels & Brakes
    Last Post: 29th July 2010, 20:54
  5. Grinding Noise
    By v6boy in forum Engine & Drivetrain
    Last Post: 10th October 2006, 07:52
https:www.vectra-c.comforumshowthread.php56385-grinding-noise-turning-right
My 2007 vectra making a metallic noise when turning right
insignia noise when turning right
vauxhall zafira grinding noise when turning
Vauxhall corsa grinding noise when turning right
vauxhall insignia strange noise when turning right
vauxhall insignia noise when turning hard right
vauxhall insignia noise when turming hard right
bad grating sound when cornering vauxhall combo
vauxhall insignia brake sounds when turning
