Thread: rear power supply cover
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    Default rear power supply cover
    hi all ive just bought a whole replacement for the rear power supply. the problem i have is that the connector is different to the plug in my car? i bought the one with the 12v cover on whereas before it had a lighter in?? were the plugs change for the facelift models? if so is there any way i can get it to work? tia
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    the connector should be the same !!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    there was a change form a lighter to a 12v accessory one. It looks like the plug has changed as well. Can you split the plug up and use it?
    Feb 2007
    Quote Originally Posted by merikiito View Post
    no the new one is just 2 metal prongs on the base whereas the older one has a plastic connector on the bottom ill try and get some pics now!!!
    Feb 2007
    here we go
    Feb 2007
    could i cut the plug off and solder the wires onto the new on????
    Engine : 2.2 Direct
    well i can see the differnce.. (mine is just the new one)
    Yes you should be abel to to that.. but would be easyer just to use "spade connectors" instead of solder.
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    Quote Originally Posted by kenp View Post
    Yep use the connectors, much easier, Maplins/Motorworld/Halfords all sell the bits!
    Feb 2007
    cheers i forgot about spade connectors will get some this weekend and have a go!!
  1. rear 12v power supply???
    By big rich in forum Electrical & ICE (including SatNav)
    Last Post: 29th November 2010, 22:38
  2. Rear power supply fitted behind arm rest
    By merikiito in forum Parts for sale
    Last Post: 11th November 2008, 22:51
  3. Rear Cigarette Lighter - Power Supply - Help !
    By mickyd98 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd August 2008, 17:22
  4. remove rear power supply in hatchback
    By vectragsi3.2 in forum Electrical & ICE (including SatNav)
    Last Post: 10th April 2008, 20:14
